What Kind of Face Mill is This?
Results 1 to 14 of 14
    Dec 2019
    61
    24
    Default What Kind of Face Mill is This?
    He is using it to leave circular grooves in a face. Is this some sort of fly cutter? It looks asymetrical. Video: Face Milling
    Jul 2006
    Hillsboro, New Hampshire
    10,824
    2528
    7600
    Well, the video is almost useless, but it seems to be a flycutter body, perhaps with a specially ground tool to leave the desired pattern.
  3. Likes Mike1974, sdinzy liked this post
    Dec 2019
    61
    24
    Sorry, it's all I've got.
    Nov 2009
    CANADA
    British Columbia
    45
    24
    11
    Definitely some sort of one-insert fly cutter. I guess you fudge the chipload to equal the stepover you want?
    Youtube - How to Face Knurl with a Fly Cutter
  6. Likes Ethan Scott, sdinzy liked this post
  7. #5
    Dec 2019
    61
    24
    Quote Originally Posted by kinetiq View Post
    I had never even heard that term before, face knurl. This is exactly what I was hoping to find, thank you kinetiq!
  8. #6
    Jan 2007
    Flushing/Flint, Michigan
    9,468
    520
    7867
    Really? And not even done right.
    Not so good face knurl in my world Note top to bottom pattern.
    I would be screaming upset with this part to be shipped to a customer.
    The process is simple and can be done with a face mill or flycutter.
    Bob
  9. #7
    Dec 2019
    61
    24
    Bob
    Bob, how would you do this with a face mill? I had actually posed that question earlier in the year and you responded to that thread. But if I remember correctly, it was along the lines of tilting the machining table, which is not a viable solution. If there was a face mill I could purchase with a specific insert I could buy off the shelf (instead of grinding one myself), that would be the ideal solution.
  10. #8
    Jan 2007
    9,468
    520
    7867
    TPG-321 or less rad and a whole lot of feed and maybe leave all but one pocket empty if the feed rate higher than your machine can handle
    Feed per tooth and a geometry in the cutter and insert that can cut a groove.
    One can not do this with APKT or SPKN since it has a flat on the bottom.
    You need a proud tip that makes the groove shape you want.
    Tilting the head has to do with if you want the trailing "crisscross" grooves or not.
    Cheapo TPG cutters are hated for many reason and rough finish is one. Here you want rough finish and feed them crazy, insane fast.
    The feed per tooth is your pattern, shape of the cutting edge presented and its tail is the shape of the groove.
    Bob
  11. Likes sfriedberg liked this post
  12. #9
    Dec 2019
    61
    24
    Bob
    Thank yoh Bob. Do I need a certain angle face mill? If you could recommend some specific products, it would be appreciated. I’m sure the manufacturer would be happy
  13. #10
    Jan 2007
    9,468
    520
    7867
    What do you want the grovve to look like or profile.
    Lets take to ultimate cheap TPG holder with a .006 rad tool in it.
    90 front edge, small rad and a leadout on the back side.
    30 or 45 on both walls of the groove not so easy and here is where you see custom flycutter or inserts.
    It is not that I want this pattern, also what shape do I want this pattern to have in the grooves.
    It is not looks like sort of like this.
    Bob
  14. #11
    Dec 2019
    61
    24
    Bob
    I've been using a 120-degree engraving bit to achieve the desired effect, so ideally I'd like to stay with that angle of groove. I'm only creating grooves that are 3-6 thou deep.
  15. #12
    Feb 2007
    Boston MA
    1,152
    536
    1054
    I used to do this all the time for a customer I previously worked at. Standard face mill with TPG insert with a small nose radius, only using one insert in the cutter body, then a specified RPM and feed to get the pattern you want. That particular customer wanted .100 overlap on passes. It created sort of a spirograph type effect, but in a line instead of a circle.
  16. Likes sdinzy liked this post
  17. #13
    Dec 2019
    61
    24
    Quote Originally Posted by SRT Mike View Post
    I thought I had tried this already, but I'll give it another shot.
  18. #14
    Dec 2012
    Se Ma USA
    1,857
    150
    1013
    Reminds me of this. But this is done by hand. Duck breast.
