You can get both topping inserts or partial profile inserts in laydown or in top notch.
Triangular threading inserts, with one cutting position per corner.What are laydown threading inserts?
Because the triangle is oriented in a horizontal plane, as if it were lying down on a table top. There are also triangular threading inserts oriented in a vertical plane, and these are often called "standup".Why do they call laydown?
Yes, you do. You cannot use holders for originary triangular inserts, because they will not hold the cutting corner of the insert at the correct compound angle.Do they need special holders?
Or even the old standup triangle.You can get both topping inserts or partial profile inserts in laydown or in top notch.
Don't know, but I was using Sandvik laydowns in the late seventies ...And who started this tool? Carmex only came about in 1988.
Because they work ?Why did it become so popular so fast?
Standup triangles used to put pressure on the cutting edge that wasn't being used in the holder. When you lost one corner you frequently lost a corner in the holder as well. The laydown style holds the insert better.What is so different about it from a standup triangle?
So which better for cost, performance and strength?
Why did it become so popular so fast? What is so different about it from a standup triangle?
Bob
Bob
On the chance that you're serious about this, the laydown is much better than the standard style.
Especially the full profile inserts. Cost is more obviously but the quality of the cut thread is worth it.
"The Vardex indexable laydown thread turning insert technology was developed over 50 years ago"
https://www.vargus.com/thread-turning
The other unusual thing about them (at least the sandvik ones) is since they are flat across the top, you can plunge straight in rather than at a 30* angle. Tool salesman recommended that to me, ah said, "You'se da boss, learned all these hotsy-totsy new tool tricks from the factory" and tried it ... worked good. Strange chip but nice threads. More even wear on the insert, more parts per corner. At $10 apiece that was a good thing.
From my research, $10 each sounds dead cheap. Are the $10 ones any good? No immediate need, just asking.
Notice
