I have ran Manchester (now flying under the Widia name - but Kenna has owned them for decades) for 25 years.
I have seen the newer ones offered, and some of them have sparked some interest - wondering if it's "all that" or not?
The Manchester's that I run have replaceable blades and clamps, but it is still quite expensive.
On a 2.25"D capacity tool, a new blade and clamp could be $50 or so?
BUT - that's it, and you're all freshened up and good to go again. (insert yet of course)
And the blades can normally be flipped when one side gets buggard up - depending how bad....
But these one that have 4-5 pockets in them sure seem ... interesting....
The Iscar fella just stopped in a cpl weeks ago and I talked to him about the new cut-off's that they had for bigger bars - like 1 to 3".
He had one with 78mm bar capacity and had 4 pockets, but the new blade was maybe $190 I think? Sure we could prolly git it at less than MSRP, but still....
So - even if we doo git 4 go's at it, I'm still at almost $50 per crash, but the reality is that when you blow a cut-off on 2" material, many times - there is a 1" radius in the end of your blade/clamp where your tool use'ta be. By the looks of things, your adjacent pockets still need to at least sorta be there to be able to index the 4/5 position blades, and so - it is quite possible to git only, or at least less than 4 (5) edges per multi-position blade.
This is not so much the case on <1" material. Blowing a cut-off in 3/4" stock mostly seems to blow the insert, and may likely damage the hardware, but not completely devour the whole end, thus being able to index the unit and continue.
But trying to cut off 2.5" 304SS - when that insert takes a Shiite, you will be losing some hardware.
To answer the Q about what holder for subs, depending on the machine, but I either have two cut-off's in the machine (LH and RH) or in one machine I actually built my own holder that will take either LH or RH 2.25" capacity Manchester hardware.
Think Snow Eh!
Ox
