What rust inhibitor areyou using for your machines?
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Jul 2014
    Virginia
    269
    107
    25
    Default What rust inhibitor areyou using for your machines?
    My machine doesn't run everyday, some days may only run 2-3 times a week. Before every shutdown I wash the machine down (with tool in the spindle)and last thing I do is wipe the spindle down with lint free towel. If I know I'm not going to use the machine for a while I'll spray some wd40 on the tool holders and spindle... I know I should be tar and feathered. I have LP3 but I don't like the waxy residue left behind. Have to have a solvent to remove it before use.
    A friend recommended CRC3-36, I just picked some up today.
    What do you guys use on your spindle taper and your tool holders? Do you use a solvent/other to remove it before using the machine?
    Jun 2012
    Michigan
    5,087
    4638
    3065
    if we only use a machine 2-3 times a week I wouldn't even worry about rust prevention, your coolant should leave an oil film.
    Does your shop have higher than normal humidity?
  3. Likes Djstorm100, Bobw liked this post
    Jul 2014
    Virginia
    269
    107
    25
    Humidity stays pretty normal. If I’m running both machines with flood turned 100% on, the humidity will start to rise to about 58-62% in. 70-72degree shop
    I just wipe everything down, as a way to inspect the machine and keep everything in tip top shape. I’m a one man band, lol
  5. Likes Mtndew liked this post
  6. #4
    Nov 2019
    FINLAND
    76
    28
    8
    I also use occasionally my machines and after use apply some ISO-32 hydraulic fluid on way covers as well as lathe ways. Then by paint brush lather it to every exposed metal surfaces. I don`t use flood coolant though so maybe overkill, but I`m quite anal in taking care of my precisious tools.. Hydraulic fluid has rust inhibitors and you don`t need to wipe it off.
  7. Likes BGL liked this post
  8. #5
    Aug 2002
    West Unity, Ohio
    26,073
    6365
    8529
    Quote Originally Posted by Djstorm100 View Post
    I can shut mine down for 2 years and not have rust all over.
    What coolant are you using?
    Synthetic? (I don't)
    Maybe your coolant is separated?
    Maybe you want to ask your coolant supplier what the working Ph level is s'posed to be, and fetch some test strips, and maybe some Ph adjuster snake oil?
    (I doo)
    Or, maybe just keep a spray bottle of fresh/heavy concentrated coolant at the machine to use to spray down when done.
    Think Snow Eh!
    Ox
  9. Likes Bobw liked this post
  10. #6
    Nov 2004
    Yankee Hill / California
    446
    322
    40
    The CRC3-36 is exactly what I have been using for 20+ years. Good stuff!
    Murf
  11. Likes Djstorm100 liked this post
  12. #7
    Jun 2015
    Minnesota
    507
    9
    179
    I'm another who is not on board with this. I'll have a machine down for weeks sometimes and still no problems at all other then perhaps a vise left on a table too long and staining. I've now switched to QualChem 251C on all my machines. When that stuff drys back it leaves puddles of what appears to be pure oil. Can't imagine needing to add anything else. Even vises left bolted down for weeks show no problems at all when removed.
    I have had small issues on my horizontal saw though using full synthetic.
    Other then a quick wipe down on the tool holders they get nothing else. They're mostly stored in closed cabinets. I tear my tools down after every job, so I have 20 year old holders that are still in excellent shape. No added protecterant ever.
    Remember hardened and ground surfaces like on tool holders and spindle bores get a somewhat not-by-design free benefit in that they are far less prone to corrosion then plain metal surfaces.
  13. Likes Djstorm100 liked this post
  14. #8
    Oct 2005
    Wilmington DE USA
    2,081
    321
    426
    I've been using wd40 on aluminum in manual operations
    Does the CRC3-36 perform same way for aluminum ?
  15. #9
    Sep 2006
    Abingdon, VA
    3,484
    4710
    3325
    On a related note, I've always been astounded at how so many shops will let their vmc tool-holders and spindle bores get just terrible!
    I like to see "shiny new-looking" tool-holders, even years down the line. I will always stone any high spots on the shanks, and I like to use dull, extra fine/soft Scothbrite to give the tool shanks a whirl by hand when they need it.
    Yeah, you're not really supposed to do that because you can actually be removing material from the shank ...but I figure that's still better than letting crud and dings just overrun the entire tool shank...and thus the spindle!
    ToolCat
  16. Likes Ox, Djstorm100, Bobw liked this post
  17. #10
    Nov 2004
    446
    322
    40
    Quote Originally Posted by mjk View Post
    I use it for drilling/ turning aluminum all the time. I have never used wd40 so have no comparison to share. I wipe all my machines, tool holders and cutting tools down with the 3-36 and have never had rust issues. YMMV
    Murf
  18. Likes Djstorm100 liked this post
  19. #11
    Feb 2004
    Napa, CA
    2,632
    45
    697
    My machines may go for days, weeks, or months not being used. The corrosion problems I have are the unseen surfaces. Anything that can be seen - open to the air - dries quickly leaving an oil film from the coolant. However in places like under the vice jaws, between the soft and master jaw, under the vice bodies, it does not dry. Even two months on, take it apart and it's wet in there. And corrosion is happening. Worse between dissimilar metals but also even between like metals. Under the vice bodies I've taken to bedding them in anti-seize, which seems to mitigate corrosion for a long time. Can't really do that with the vice jaws. Spraying with WD or CRC or whatever has a small effect, it does not penetrate where the corrosion is. I've found no solution other than take the vices apart so they can dry.
    This is in a very low humidity environment, 35% is typical.
  20. Likes Djstorm100 liked this post
  21. #12
    Jul 2014
    Virginia
    269
    107
    25
    (I doo)
    Think Snow Eh!
    Ox
    I'm not fighting any rusting issues or anything like that. Just asking and seeing what other people are doing to keep their machines in great shape is all. I don't like WD-40 for really anything.
  22. #13
    May 2002
    South Central PA
    13,829
    2403
    3644
    Starrett M1. It's essentially vaseline in solvent with a few other anti rust ingredients like Lanolin. Expensive by the can compared to WD40 etc, but it's the best we've tried, stays easy to wipe off and most of all does not stain bare metal.
  23. Likes neilho, Djstorm100 liked this post
  24. #14
    Jan 2007
    Flushing/Flint, Michigan
    8,633
    465
    7084
    ...... If I know I'm not going to use the machine for a while I'll spray some wd40 on the tool holders and spindle... I know I should be tar and feathered......
    Not gonna be tar and feathered from here, we use it all the time on holders, vises, fixtures and even gauge blocks.
    All my coolant is water and synthetic, oil...yuck.
    LPS3, yuck and goo. Good for long term storage but you can not pick it up, wipe with a lint-less towel and use.
    Run your coolant concentration on the high side of allowable.
    On machine mating surfaces, chucks and spindle mounts I use Mobil SHC-630 which is a gear lube.
    Antisieze also good but it is a bit thick and influences mounting if not spread evenly.
    In these a homemade paste made of white grease and STP also lasts a long time.
    But for toolholders in the rack and spindle taper not in use WD-40 is my go to after many decades of trying and being sold on so many products.
    Obviously if starting a machine not used for weeks or months you wipe and clean the taper before sticking anything in it and the same with holders.
    I do know many hate it as "magic oil".
    Bob
  25. Likes Djstorm100 liked this post
  26. #15
    Mar 2006
    Vershire, Vermont
    2,216
    1476
    719
    Quote Originally Posted by Mud View Post
    What Mud said...
    Smells much better than WD40, too.
  27. Likes Djstorm100 liked this post
  28. #16
    Aug 2006
    North Carolina
    112
    17
    9
    I like LPS1, it's what I use on most things these days.
    LPS2 for longer term storage.
    LPS3 under the mill vise.
  29. Likes steve-l liked this post
  30. #17
    Feb 2005
    9,213
    14817
    11021
    Quote Originally Posted by swarf_rat View Post
    I'm not a coolant professional, but my gut is telling me that you have a PH problem.
  31. #18
    Feb 2018
    THAILAND
    30
    23
    16
    I see so many with clean and dry machines (at least in the YouTube videos) but my lathe is always covered in oil, lots of it.. I do a wipe down with an oily rag nearly every day but must coat it with oil IMMEDIATELY after cleaning it up. I live in Thailand where daily outside ambient temperatures is 30C to 38C, with outdoor relative humidity approx. 80% on average, and use aircon when in my shop. So if I don't use rust prevention surface rust shows easily the next day.
    For a quick application, I use a cheap aerosol oil which gets into the nooks and crannies, and attracts dust (unfortunately). As a novice, I don't know if this the "right" way, but it seems to work... if I don't forget to spray?
    On the other hand, in my Canadian garage where the weather is much different, rust hardly forms after even months.
  32. #19
    Jul 2014
    Virginia
    269
    107
    25
    Quote Originally Posted by Bobw View Post
    as in to high of a PH?
  33. #20
    Dec 2009
    Australia
    38
    6
    Tried a Lanolin based anti corrosion product, but it seems the rats around here have a fetish for it. So had to give that idea the arse.
    Use a water based coolant on one machine and the largest bandsaw. Apart from a bit of staining under the vise, seems fine on the table if left for a bit. However do need to find something that stays on better on vertical surfaces (column etc..)
    The lathe, just sewing machine oil for cutting fluid and the unpainted surfaces.
    Presses, ISO46 in the oilers, which ends up coating the rest anyhow.
    Will give the CRC3-32 a go.
    None of my gear is in cabinets, so its canvas covers with a square of mesh sewn in the side. Found the mesh reduces the condensation factor under the cover.
