What tool to drill AND bore 5/8 hole??
Results 1 to 14 of 14
    Jan 2003
    605
    130
    195
    Default What tool to drill AND bore 5/8 hole??
    Have a job where I need to drill and bore some 5/8 holes about 1" deep in delrin. Would like to do this with one tool to save time and toolchanges.
    What would you guys recommend? Any solid carbide tools designed to do this? May just try it with a 2FL endmill, but wondering if there is something better out there?
    Oct 2009
    Oregon
    6,027
    6501
    3363
    You can drill and bore on a lathe with an indexable drill no problem, but on a mill? I don't follow.
    Maybe describing what you need the end result to be? If a through hole maybe a dreamer would do it? Otherwise 2fl EM sounds like a winner if it will do better than a drill for ya.
    Jan 2003
    605
    130
    195
    This will be on a lathe. I guess im looking at 1/2" tool or so. Ive never had much luck with indexables smaller then 3/4". You think it could work?
    What about something like this? Single flute endmill? Plunge in on center and then bore to size? McMaster-Carr
    Sep 2015
    Ohio
    1,779
    1172
    1901
    I drill and bore with 2 flute endmills. Works fine, especially in plastic.
  5. Likes kustomizer, SeymourDumore liked this post
    Mar 2015
    Michigan
    540
    130
    243
    I did exactly that (same material also) once on a lathe but it was out of necessity rather than by choice - I ended up using a nice, sharp HSS endmill instead of carbide and it worked out really well for that job.
    Feb 2020
    Alabama
    366
    151
    104
    3/8 carbide endmill 3 flute
    Nov 2019
    UNITED KINGDOM
    76
    38
    Ceratizit Ecocut/WNT Ecocut/Arno Sharkcut would be my first choice, preferably with a ground uncoated insert, that is what I normally use for any holes above 10mm diameter and within the depth the drills can do.
    I'd use either a 12mm or 14mm 2.25xD version, I'd bet there is a 5/8" version available too in which case you could probably do the hole in a single pass.
  9. Likes GENERALDISARRAY liked this post
  10. #8
    Jun 2012
    Michigan
    5,922
    5585
    3775
    Just use a HSS drill. What is the tolerance you need to hold on the size?
    Is it a thru hole? Or a 1" deep blind hole?
  11. Likes BT Fabrication liked this post
  12. #9
    Mar 2016
    Illinois
    934
    177
    533
    Flat bottom drill, spiral cut a 3/8 endmill, standard drill,
  13. #10
    Feb 2012
    1,607
    982
    1827
    2 flute "drill mill" if it's a thru hole.
  14. #11
    Jan 2007
    Flushing/Flint, Michigan
    10,461
    604
    8482
    Is what you are after a flat nose or flat bottom drill?
  15. #12
    Jan 2006
    143
    185
    10
    I recommend this tool, It’s awesome in aluminum and would be great in delrin:
  16. #13
    Oct 2020
    Missouri
    24
    50
    Use a 2 flute 1/2" HSS endmill with a low flute angle, stay below 30° plunge pilot, step over to finish diameter
  17. #14
    Nov 2013
    Eastern Massachusetts, USA
    7,013
    5969
    6391
    Perhaps something like McMaster # 8905A17?
    Says it's for hard materials but probably would work fine in Delrin.
