What tools to mill black zirconia
Results 1 to 17 of 17
    May 2019
    MALAYSIA
    5
    Default What tools to mill black zirconia
    I want to make a rotor with black zirconia. so far, we have tried a PCD end mill with diamond coating D2 x 4 but the coating wear off quickly? Is there any recommendation on which tool to be use?
    Jul 2006
    Hillsboro, New Hampshire
    7,852
    1836
    5519
    If this is a ceramic material you're trying to mill, you can't - not without some laser assistance. Look into diamond grinding pins, which will have to work much slower than an endmill but with patience can shape ceramics.
    YouTube
    Apr 2019
    CANADA
    Alberta
    13
    Zirconia, alumina, beryllia...all are hard ceramics that can only be machined by grinding with diamond tools. Cutting out of flat sheets can be done on a waterjet.
    May 2019
    MALAYSIA
    5
    Im doing parts that require high precision and it is a disc shape with gear like teeth around it~i wonder if PCD tool or tool with diamond coating will do the job? how do i choose the diameter of the tool and other specification for the tool?
    Jun 2004
    Melbourne Australia
    5,458
    Fuck, you don't want much on your first ever post. Dr. Google tells me that's about 8/10ths as hard as diamond on the Mohs hardness scale.
    I'd predict no one here will tell you that. And no, its not the race card. If i could cut that, I'd be keeping that knowledge entirely in-house / proprietary.
    You might try a lapidary forum.
    Regards Phil.
  6. Likes DavidScott, Limy Sami liked this post
    May 2007
    Massachusetts
    1,427
    469
    1220
    Quote Originally Posted by zackjong View Post
    Tool selection is entirely dependent on part geometry. How can we help you Spec tools for a part we can't see ? But as others have said this material is not cutter friendly and grinding may be the way to go.
    Good luck friend
    Make Chips Boys !
    Ron
    Jul 2012
    Washington
    2,984
    1167
    1234
    You have to grind it with diamond and getting the right tool is EVERYTHING, well that and using it correctly. Just a little off and a few seconds, hell half a second later the working part of the tool is now chips. Judging by your questions I would say this is WAY over your head. I have been machining quartz and ceramics for 18 years now and it sounds like this would be a very challenging job for me, one I would not give a firm bid on.
  9. #8
    Jul 2006
    7,852
    1836
    5519
    David, have you checked into laser assisted ceramic machining? I first became aware of it years ago, a Fraunhofer Institute project at the time, but never had any personal experience with it. It does look intriguing...
  10. #9
    Jul 2012
    Washington
    2,984
    1167
    1234
    I never knew of it until that video. I wish they would have shown the roughing since they don't show much material removal until the thread. Everything I have done is basic 3 axis milling. The ultrasonic methods always intrigued me but I never have seen one work.
    So talking about it got me to searching for a video and found an nice one here. Check out the tool at 1:09, looks like something I made a few years ago. It is an ER11 taper with a 1/4" router nose. This was just an extra that I never had diamond coated. My version nixed the nut and screwed in from the back with a SHCS as the "drawbar".
  11. Likes Milland liked this post
  12. #10
    Nov 2014
    Colorado
    2,981
    3498
    837
    This is confuuusing as there are "Peeps" that happily machine Black Zirconium metal...
    https://www.espimetals.com/tech/machiningzirconium.pdf
    But / And
    There are "peeps" that jig grind materials like Cubic Zirconia (ZrO2) and Zirconia Toughened Alumina
    High Accuracy Grinding of Hard Materials Using a Hauser Jig Grinder with Robotic Automation - Insaco
    Does OP / @jackjong really mean Zirconia not (black) zirconium ?
    Zirconium alloy - Wikipedia
    ^^^ Various Zirconium alloys... Main application in nuclear industry ; (good at neutron absorption without adverse effects .).
    @jackjong do you have a print / diagram you can share ?
  13. Likes adama liked this post
  14. #11
    Sep 2010
    Vancouver Canada
    945
    703
    340
    Further to Cameraman, are we talking machining Zirconia bisque, if that's the right word, machined prior to firing in a kiln?
  15. #12
    May 2019
    MALAYSIA
    5
    img_6065.jpg the drawing at the left is the one that i want to produce and the raw material is at the right. the only description for the material is only black zirconia~
  16. #13
    Jul 2006
    7,852
    1836
    5519
    If it damaged your diamond coated tools I'd guess it's a ceramic, not metallic material. If you have a high speed spindle you could try diamond grinding pins, or maybe there's some sort of laser ablation or electron beam machining method that could work. But those aren't standard shop tools, they're getting pretty exotic. Ultrasonics is probably the most realistic "out there" technique.
    What machines do you have?
    Electron-beam machining - Wikipedia
  17. #14
    Sep 2009
    Apex, NC
    1,510
    749
    Quote Originally Posted by rcoope View Post
    Yep, most everthing made from high-temp refractory ceramics is done in the green state (whether cast, machined, pressed, punched, molded, etc). In addition to being almost impossible to work with after firing, any sort of mechanical operations after firing drastically reduces the mechanical properties due to microcracks in the surface, versus the as-fired surface.
    (worked on a couple of small stressed sensor parts in the past made from pressed and sintered zirconia and alumina, and if those parts were touched those with any operation after firing (we tried grinding versus press and firing parts), the strength of the parts was degraded by about half). Another project dealt with pyroceram (same material as the old corningware) (glass-ceraminc, not refractory ceramics) nose cones. The nose cones were cast/pressed out of pyroceram (about 10" dia and 20" tall) onto an inside mold, so the inside surface was smooth. The outer surface had to be ground to a specific variable wall thickness, which introduced microcracks into the surface, lowering the fracture toughness and thermal shock resistance. So they would take the nosecones and dip them in a molten salt bath which would effectively etch and create a slightly "foamy" phase on the surface, rounding off all the microcracks to restore much of the fracture toughness.
    A friend has a dental lab and machines zirconia restorations in their dental mill; this is green zirconia fired after machining (~15% shrinkage accounted for in the cad-data).
    If that part is already-fired zirconia, I hope there's a BIG budget for it if trying to machine it, otherwise consider machining/pressing/casting and firing green material if justified.
  18. Likes cameraman, rcoope liked this post
  19. #15
    May 2019
    MALAYSIA
    5
    we are only using simple cnc cut here~this is the tool we bought for the test run~the diamond coating just chipped off after milling the outer surface of the material. img_6066.jpg
  20. #16
    Jul 2006
    7,852
    1836
    5519
    Check out this site: Diamond & CBN Internal Grinding Pins
    I expect you'd get essentially the same stuff from China, a search will find a lot of hits. You want short pins, course and fine, and as much speed and flood coolant as you can get. A spindle speeder will help, just be sure it's a rigid design, if it's not it can't control the pin location well and you'll damage part and pin.
    Slow feeds, experiment with process parameters until you get something that's reliable/repeatable. May want to add a filter to your coolant system to capture some of the abrasive dust (both ceramic and diamond).
  21. #17
    Jul 2012
    Washington
    2,984
    1167
    1234
    It looks like the center hole in the blank is too big. Looking through the center hole of the blank it looks like the part is REAL thin in the center. Just a thought but from what I am hearing and seeing so far it looks like no one involved in this project has a clue, or your black zirconia isn't what we think it is. Did any of the tools you tried cut your blank much or did they immediately fail? If they cut at all a photo of the part and the feeds, speeds, and tools used would help.
