NickStylecnc
- Sep 5, 2018
The laser engraving machine adpots laser beam to leave permanent marks on almost nonmetal, and metal like Glass,Wood,Jeans,Silicone,bamboo,carton box, Coconut, paper, stainless steel, aluminum, copper, brass, etc.
What advantages of laser engraving machine?
1. The pattern of laser engraving, anti-counterfeiting function is strong, and graphic exquisite, fine lines, washing resistance, wear resistance.
2. Environmental protection and energy saving, no pollution, do not contain any toxic substances, convenient through the ROHS standard, convenient production.
3. Save material: laser processing with computer programming, can put the different shapes of products to suit cut, maximize the utilization rate of materials, greatly reduces the enterprise the cost of materials.
4. Precision: laser engraving the thin line in the material surface can reach 0.015 mm wide, laser cutting notch width is generally 0.1 ~ 0.5 mm, welding cold welding seam formation, no heat affected zone.
5. Material is not easily deformed: laser machine have fine laser beam, the high speed, energy concentration, quantity of heat is small, so to be processed material cause deformation of material also is very small.
6. Surface processing: laser engraving machine, welding surface without burr, good surface finish. Can greatly shorten the development period of new products.
If you want to know more about the laser engraving machine, welcome to visit: What work can the laser engraving machine do?
