I am asking this question because I have never used round inserts.
My intuition says that, because it has wider engagement, it would cause a lot of radial thrust on the workpiece.
Consequently, it perhaps cannot be used for heavy cutting, specially when workpiece rigidity is an issue.
On the other hand, when put on a neutral holder, it can circumvent interference issues while machining a pocket on a lathe.
So, where do we use it? What are the usual cutting parameters (DOC and mm/rev feedrate) for machining mild steel?
