Who Has The Best Plunge Mill
Results 1 to 20 of 20
    Jan 2008
    Kansas
    206
    97
    47
    Default Who Has The Best Plunge Mill
    What's your favorite Plunge mill? I use a .625 dia inserted replaceable head high feed mill from Seco, roughing a slot that is .642 wide and .375 deep some of the slots are up to 10' long, 5500 rpm 75 ipm with a .1 step over, the tool has always worked great, but we have been using it for a few years now, and I just feel it's time to look at upgrading the process, I know the 1st thought is why dont you just mill it, well we did for a while but with the fixturing and the part on the tombstone on our horizontal we just have to have to long of a reach, with the plunge mill all the force is back toward the spindle, so less side load on the cat 40 spindle and tools last longer.
    Thanks for the Replies
    Jun 2012
    Michigan
    5,858
    5536
    3739
    My first choice would be Sandvik.
    How long of a reach do you need?
    Nov 2019
    CANADA
    Ontario
    555
    848
    130
    Only plunge mills I know of are the unintended rapid Z moves. lol
  4. Likes Mtndew liked this post
    Jan 2008
    Kansas
    206
    97
    47
    Quote Originally Posted by Mtndew View Post
    little over 6"
    May 2019
    1,911
    1056
    1228
    I run mostly Kyocera with the LOGU030310 inserts in the small stuff, Tungaloy and Walter for the bigger stuff. But I rarely plunge mill
    Jun 2012
    Michigan
    5,858
    5536
    3739
    Quote Originally Posted by chucker View Post
    little over 6"
    I know nothing of the Seco line, but look at the EH holders from Sandvik, they're awesome, screw on cutter.
    We have a 1" 3 flute R390 in a holder with about that much reach and it cuts like butter, it's also non -dual contact so that's saying something.
    If Seco is still a part of Sandvik, they might have something similar.
    Jun 2019
    755
    330
    831
    Dijet's Super End Chipper mills work great at plunging. If you only want to use them for plunging then you can get the modular head that attaches to a solid carbide shank and go to town with them. Just be prepared to pay for them, but in my experience they work great and are well worth the price.
  9. #8
    Jan 2013
    Louisville, KY
    3,265
    7923
    2802
    Um, You do know that the HIGH FEED REPLACEABLE TIP on your Minimaster tool, can be used as a true HIGH FEED endmill, and still direct much of the cutting force back into the spindle, don't you...?
  10. #9
    Jan 2013
    Louisville, KY
    3,265
    7923
    2802
    Just FYI - Seco, Walter Tools, Sandvik Coromant, Precision Twist, Dormer-Pramet, and Safety (pronounced soff-uh-tee) and all of their sibsidiaries, are all part of a division of Sandvik Co - the large Swedish conglomerate which has its hands in metals production, mining equipment, hard materials (diamond, CBN raw materials) etc. Sometimes nick-named "Blue Sandvik" as their logo is blue... Contrary to popular though, there's not all that much technology sharing between the different sister companies, especially on the carbide insert side of things. They do share common production of steel tool bodies, but that's about it. Naturally, HR & benefits are all aligned under the "Blue Sandvik" policies...
    Back on topic, your Screw-On R390 cutter is compatible with Walter's system, although the inserts etc. are not compatible. Seco's "Combi-Master" system is not compatible with that of Sandvik Coromant, and/or Walter's.
  11. #10
    Jan 2008
    Kansas
    206
    97
    47
    Quote Originally Posted by Jashley73 View Post
    Yes you are correct the high feed was the direction I went from regular milling but with that long reach we found that we were bell mouthing our cat 40 spindles that's why we went to the plunge milling.
  12. #11
    Jul 2006
    Hillsboro, New Hampshire
    12,783
    2905
    8846
    That's interesting. Usually toolholders are softer than the spindle taper, did you notice abnormal wear on the holder taper too, or just the spindle bore? And who's the machine manufacturer?
  13. #12
    Feb 2007
    Aberdeen, UK
    4,542
    1656
    2108
    BTDT.
    It doesn't matter that the holders are softer, the material is removed by fretting, not wear.
    High feed milling, if you are really chasing MRR, is hard on spindles that are not dual contact.
  14. #13
    Jan 2013
    Louisville, KY
    3,265
    7923
    2802
    I don't mean to be a jerk, but a 6" gage line tool, with a 5/8" diameter milling cutter should not be damaging a 40-taper spindle.
    Is the total gage-length of the tool really just 6" long, or do you have to have a 6" of the cutter's shank hanging out of the collet - meaning a 10-14" gage-length?
    For reference - I can put together a 2" diameter high-feed mill on a 6" long holder, and still cut 75-100" minute in 4140 pre-hard steel, on some old, junky, asian import 40-taper machines.
    If you cannot high-feed mill with your 5/8" Seco Minimaster tool, something else is bad-wrong with your machine, or your setup...
    Edit - I thought of this after typing the above...
    What's your favorite Plunge mill? I use a .625 dia inserted replaceable head high feed mill from Seco, roughing a slot that is .642 wide and .375 deep some of the slots are up to 10' long, 5500 rpm 75 ipm with a .1 step over.
    5500 RPM on a 5/8" diameter cutter = 900 sfm. That's awfully fast for that tool in steel. About 50% too fast on average.
    Just what material are you cutting anyway? Putting the pieces together, you said Kansas, 10-long parts, 40-taper HMC - are these aircraft related, aluminum parts by chance?
  15. #14
    Feb 2007
    Aberdeen, UK
    4,542
    1656
    2108
    I missed the size of the tool he was talking about.
    Agree there is absolutely no way that should hurt the spindle taper in a million years.
  16. #15
    Jun 2012
    Michigan
    5,858
    5536
    3739
    Yes, I'm well aware of Sandvik and their other companies and how they operate.
  17. #16
    Jan 2008
    Kansas
    206
    97
    47
    Just the spindle
  18. #17
    Jan 2008
    Kansas
    206
    97
    47
    Its 1018 it is now aircraft thankfully.
  19. #18
    Jan 2013
    Louisville, KY
    3,265
    7923
    2802
    How long is the tool, from tip to gage line?
  20. #19
    Jan 2008
    Kansas
    206
    97
    47
    6" holder 1.1" stick out on tool total of 7.1"
  21. #20
    Jan 2013
    Louisville, KY
    3,265
    7923
    2802
    Again, not to be a jerk, but something is bad wrong with your machine. In 1018, you should be able to take any cut you want with that cutter, at that length, in basically any spindle.
    The first thing I'd be checking is drawbar tension.
