Who makes the best Indexable endmill/facemill with a CBN insert for hard milling?
Results 1 to 10 of 10
    Mar 2014
    Santa Cruz, California
    36
    Default Who makes the best Indexable endmill/facemill with a CBN insert for hard milling?
    Iíve got some hardened D2 steel parts that need to be as nice as I can possibly make them. This is part of an assembly and I canít send it out for grinding.
    The part is similar to a collet, where I need to face the top and profile the outside (itís not round so it canít be done in a lathe). The flatness of the top needs to be as good as possible, and the profile of the outside needs to be fricking tight. No hard tolerances, just as good as possible.
    I remember when I toured the haas factory a couple years ago they were using a flymill with a single cbn insert to mill surfaces flat within a Few tenths. So my original thought was to copy that with a sandvik cbn facemill to make the flat and then use a nice endmill to profile the outside.
    But.... i would really like to use a single indexable endmill with a
    single cbn insert to both profile and make the flat with one tool. Anybody done anything similar or can recommend any tools that fit the bill? Iím a newbie to tool steel so I may be way off base, if so let me know any other ideas (my generation thinks ďbillet aerospace aluminumĒ is the secret sauce to every damn part, so its rare I do anything else).
    Mar 2014
    36
    Part is around 2” in diameter, so I won’t be facing much. The profiling around the outside is only .1” deep.
    Jun 2012
    Michigan
    3,706
    3212
    2142
    Look at Sandvik Century facemills
    Mar 2014
    36
    Quote Originally Posted by Mtndew View Post
    Even for profiling? I thought that was a non starter
    Jun 2012
    Michigan
    3,706
    3212
    2142
    Quote Originally Posted by Adams View Post
    Oops, I assumed you just wanted a facemill.
    Those are not for profiling
    Mar 2014
    36
    I am tempted to get the 50mm Century with the pack of the CBN inserts and see how it handles. The profiling depth is tiny.
    But those dudes are almost 1 grand, bit of a pricy experiment.
    Dec 2007
    Southeastern US
    6,270
    762
    2648
    Mapal or IT.TE.DE (Ingersoll) can do that, but not sure they would have something in stock.
    Feb 2007
    Aberdeen, UK
    2,955
    1051
    1042
    Sandvik have a few other CBN options besides the Century.
    R490 for example is a shoulder milling insert, and is available in CBN as 490R-140408E CB50, with a 2mm edge length for shallow profiling. Body and inserts all cheaper than the century also.
  9. Likes Mtndew liked this post
  10. #9
    Jan 2013
    Louisville, KY
    2,836
    6527
    2366
    Face-mill tooling is going to be expensive. CBN milling inserts are usually high-CBN content grades (which are tougher and do better in interrupted cutting as seen in milling) - which means solid CBN inserts at $2-300 a piece.
    You could go with ceramic, but the cost of a facemill still won't be cheap.
    For a part that size, just find a good endmill with a large corner radius, and use it for the facing as well.
  11. #10
    Mar 2014
    36
    Quote Originally Posted by gregormarwick View Post
    Dude that is perfect, you are the man. The Coromill 490 is just what I need.
