Who makes the best mist collectors?
Likes Likes:  0
Results 1 to 7 of 7
    Apr 2016
    Florida
    255
    205
    77
    Default Who makes the best mist collectors?
    The shop can get a little foggy now that I have 4 machine tools in here, usually with 2-3 running simultaneously. I have a MistAway unit on one machine and it seems to do pretty well- Not a ton of flow, but it makes enough negative pressure to do the job and it's so quiet I don't even know it's there.
    Before I go buy 3 more though, I was curious about which ones people like. Is the MistAway as good as it gets, are the Royal units worth the dough, are there others worth looking at? Should I look at a big one and run ducting to all the machines, or should I run individual collectors on each machine?
    I have two 40x20 VMCs, a 30x16 VMC, and a medium sized turning center in case that matters at all with regard to sizing and such.
    Sep 2008
    1,418
    864
    776
    I have an older Royal Filtermist F-1200 on a Fadal. The only time I've ever seen coolant come out of the outlet was when using a 1/2 drill that had a large ball of swarf wrapped around it and collant at 100%. Any other end mill/drill/facemill I don't see any flow from the spigot. It does get rid of the very fine coolant smell you get when you open the doors, but that's about it. I've sprayed collant up into the inlet using a spray bottle, and collected the same qty of coolant that I sprayed in, so it does work, but only it appears with a range of droplet size. Also I went to some effort to enclose the top of the machine to prevent it pulling all the air in from the top of the machine.
    One of the reasons I got the Filtermist was to reduce coolant usage, caoolant usage as far as I can tell hasnt gone down one iota.
    The other issue with the Filtermist is the cost, there imho way overpriced for what you get, in addition the F-1200 pulls 6A and 208V 3PH so not a trivial amount of power.
    If I did it again I would get a Mistaway, 110V is conveniant, price is right, and people seem to like them.
    Sep 2008
    1,418
    864
    776
    If I had TSC on the machine, then it might be a different story vis a vis the Filtermist.
    May 2011
    No. Cal.
    364
    215
    We have 10 Fadals, mostly 4020 and 3016, all of which are now serviced by MistAways. In earlier times most were connected to central Smog Hog - but that system was expensive to install (both hanging the unit from ceiling and ducting to the machines) and expensive to maintain (cleaning service).
    The MistAways are easy to maintain and install. We also went for the gizmo from MistAway that turns on the unit only when there is current flowing to the coolant pump.
    There may be better solutions now, but MistAway still appears (to us) to be good solution at reasonable price. HTH
    Fred
    Jul 2012
    Washington
    2,388
    931
    966
    The only downside to ducting is the mist will collect in the ducting, not in the filter unit.
    I have wondered how well a larger, 6"-10", centrifugal fan would work. Restrict the flow to it to reduce the air pressure at the fan and duct it back to the machine. I have something like this on a tile saw and it seems to work quite well. The fans are $170 and up and don't use much electricity.
    Jan 2003
    Canada
    11,104
    4983
    3143
    Aeroex. These are probably the best on the market.
    I'm not sure how to embed videos on here anymore.
    YouTube
    Sep 2013
    Minnesota
    264
    73
    48
    Check out Donaldson. Their solutions are not inexpensive but the value is high.
