Why is cnc machining so expensive?
Page 1 of 14 12311 ... LastLast
Results 1 to 20 of 261
    Jan 2013
    22
    10
    Default Why is cnc machining so expensive?
    Hey guys,
    Why is cnc machining so expensive? Like, $1 per hour of shop time? And the machines themselves can cost between $10,000 - $200,000? I don't think it's the electricity - a 10KW motor only eats $1 of electricity per hour at $0.1 per KWh. And the machines are computer controlled and can be fully automated, so you don't even need to pay specialized machinists after everything's set up for mass production. You can even run the machines 24/7/365 because you don't need to "babysit" the higher end machines. And even for the ones you do need to babysit, it only takes someone to change out parts, tools, etc. so they could probably handle like, 10 machines at once, or some other job in the meantime. I see cheap diy cnc machines for under $1000 online. They might not have the size or the power, but you can probably modify the design to accomodate a larger motor - which isn't that expensive anyway. And they have tolerances to 0.005" - not bad for a $300 - $500 device.
    I can see that the cost of a machine strongly correlates with the size of the table as well. Does the motor move on precision rails? Is that driving the cost up? But why have a 4'x8' machine anyway if you won't make anything a tenth that size?
    Also, why do machining companies have to charge so much for programming for small projects? There are programs out there that can convert a 3d file directly to G-code already.
    Btw, I think 5 axis cnc machines have a lot of potential. Much more than the 3d printing thing. But all the good 5 axis machines are ridiculously expensive.
    -Gene
  2. Likes HuFlungDung, JonGeek_CNC liked this post
  3. #2
    Nov 2001
    WAPELLO, IA USA
    6,407
    29
    1840
    start adding up the cost of everything involved in making a part.... even $1.00 a minute is cheap. There is property tax, income tax, machine payment, cutting tools and expendables, toilet paper, printer paper, software maintenance fees on both the cam system and the CAD system, did I mention machine repair, power bills, and slow paying customers forcing you to get a line of credit on which you lose 5% financing the customer, and then there is payroll. Even running a programmed machine takes a skilled person, so there is no free lunch to running a computer controlled machine.
    Mar 2013
    Oslo, Norway
    31
    5
    6
    I'd say $200k USD is on the lower end for a fully spec'ed CNC machine.
    Dec 2008
    New York
    10,219
    2654
    Default costs
    Quote Originally Posted by geneiusxie View Post
    Hey guys,
    -Gene
    1st thread ?? seems you want to cause some waves?? most times the machines do not run themselves unless the tolerance is a large amount,..... you obviously do not know the cost of the cutting tools either.
    ........ programming is not that automatic as somebody has to decide on vise / fixtures needed, setup and order of operations, and pick what tooling to use. sure there is software to help out, but if software says use a 1" dia end mill and you currently have none do you think the job will stop ? or will somebody using what's available figure out the job.
    ....... the future is going mostly to making stuff on demand. i make dozens of different parts each week often making the same parts in a few more weeks. Having extra stuff in a warehouse is the old fashioned way. just in time manufacturing is what they mostly use now
  6. Likes ricardo_gt liked this post
  7. #5
    Feb 2008
    MI, USA
    810
    59
    317
    This guy will be laughing all the way to the bank when he takes 10 500$ cnc machines, put larger motors in them, then pay a single operator to run all 10 of them as they run pretty much unattended 24/7/365. He'll put us all out of business with his 10$/hour shop rate, expand the size of his shop to 50 500$ machines, while adding a second operator, and will be a billionaire before long.
  8. Likes ADFToolmaker, Mr.M, 3t3d, Greg White, Big B and 18 others liked this post
  9. #6
    Dec 2002
    Granville,NY,USA
    3,934
    333
    427
    NOT to feed a troll.
    But What do you pay for other trade work that has a much smaller over head investment. The average auto shop charges $70/HR and up. A plumber will hit you for 50 or more and he has what? a van? LMAO
  10. #7
    Jan 2007
    Flushing/Flint, Michigan
    7,971
    402
    6592
    It's a conspiracy.
    When you buy your first cnc you have to sign a "code of silence agreement".
    We all have to support our 5 houses around the globe, and our planes and boats. Not to mention the costs of the continuous string of high maintenance "partners".
    We cry about not making any money as a cover story so we can get bigger tax breaks.
    Now that I've broken the code I probably won't be around much longer.
    Bob
  11. #8
    Feb 2004
    Napa, CA
    2,606
    43
    691
    Can you please provide a link to the $500 machine with 0.005 tolerances, a 4'x8' table, the ability to add a 10KW motor and run unattended from a 3D file? I'd like to get one of those. Also, can you provide a link to the source for $0.10/KW power? My power company charges me $0.28, surely I am being ripped off...
  12. Likes Oldwrench, N/A liked this post
  13. #9
    Mar 2006
    PHILIPPINES
    2,494
    572
    812
    either the OP is just performing some sort of joke or has to be the most ignorant person to ever visit this forum.
  14. Likes dstryr, SND, wrustle, Putch, Joe788 and 12 others liked this post
  15. #10
    Dec 2012
    Se Ma USA
    1,541
    120
    857
    I just hose clamped a calculator to a Harbor Fright lathe and am gonna kick some ass...................
  16. #11
    Jan 2013
    22
    10
    Sorry if I seemed mad or anything. Just wanted to know how to cut the costs down for my own projects.
    I know that carbide drill bits can cost hundreds of dollars. But titanium nitride coated HSS bits are much, much cheaper, and might be less likely to break. They might not last as long, but I'm assuming using carbide bits is to provide a better cost/performance ratio? Anyway, that seems like a minor issue for a mass produced part because the cutting speeds and feeds should be already optimized.
    I see that most industrial machines weigh several tons. Why not make them lighter? Is it just the work table that weighs so much? Is the table just a solid block of steel or something?
    I think most cnc machines use huge industrial grade motors that low power/weight ratio and also power/price ratio. Why not use high speed brushless motors instead, like they do on remote controlled airplanes? You can get a $500 motor with 6kw of power or so and it weighs less than 2 pounds. It might not be as efficient or last as long and you'd have to gear it down too, but it would be a lot cheaper and provide a much faster return on investment.
    Is paying tens of thousands of $ for software really necessary? I see open source and free programs that can also convert 3d files to G-code. They might not be as good in terms of speed and efficiency, but I don't see how tolerances could get affected as long as you do enough passes with the cutting tool.
    Also, do most machines continuously apply lubrication to the cutting tool?
  17. #12
    Feb 2009
    Wisconsin (from May to November); Florida (from November to May)
    1,613
    46
    407
    There you go again, critizing those who are only trying to gain information. He is only asking in the spirit of inquiry. Let the feeding frenzy begin!
    Lord Byron
  18. #13
    Feb 2008
    MI, USA
    810
    59
    317
    Why are you assuming that every machining facility is mass-producing parts non-stop 24/7? It isn't nearly like that.
    Not every part is a simple 3d part that can be modeled and programmed to cut with a single tool.
    I'd answer more of your points but i'm busy and its not worth my time trying to convince you that you are way off base in your cost analysis and the ability of machines to just do everything for you with no extra intervention required.
  19. #14
    Jan 2003
    Canada
    11,274
    5418
    3406
    No expensive, see, you promise big order, give small order first, say more later, I make parts for you good price, you no pay me, no expensive.
  20. Likes g-coder05, ipmmiller, sawmill, Gregor, JG400 and 2 others liked this post
  21. #15
    Jul 2004
    Asheville NC USA
    8,871
    3610
    3023
    You guys make sure to answer all these questions. I'm too busy rollin' up hunnert dollar bills for lighting my Cuban see-gars to respond right now.
  22. #16
    Feb 2012
    CANADA
    Ontario
    1,126
    89
    433
    The OP makes me chuckle.
    On thursday i spent 5 hours programming and setting up.
    Then i went home. The part will take 6 hours to machine.
    5x30+6x50= 450$ if everything goes well. Because its a 120k machine with a couple of grand of tooling in there.
    How much per hour should a machine shop charge again?
    Booyy, i must be quite inefficient, i hope my boss doesn't see this.
    Btw it it takes 6 hours to machine a part on a 12k rpm 20hp machine it will probably take a week on a DIY lego kit OP was referring to.
  23. Likes Hertz liked this post
  24. #17
    Mar 2004
    Edison Washington USA
    10,375
    971
    5397
    Once you move out of mom's basement, you realize that $60 an hour is not enough to live on. Hell, plumbers make that much, and they have a few wrenches and a snake- they dont even spend money on belts.
    I have far less invested than a lot of full on cnc machine shops.
    And there is no way I can work that cheap.
  25. Likes Gregor, N/A, TeachMePlease, Mstcnc, Tom Lg liked this post
  26. #18
    Jun 2006
    Massachusetts
    3,234
    2357
    2411
    What g-coder05 said kinda sums it up perfectly.
  27. #19
    Mar 2006
    PHILIPPINES
    2,494
    572
    812
    A man asked me why I charged so much in a sarcastic manner one time. My reply was simple, "Because I know how".
  28. #20
    Dec 2008
    New York
    10,219
    2654
    1) things are not as easy as you think. you have the confidence of an ignorant person. after you make a few thousand (successfully to tolerance) different types of parts making decisions of what needs to be done and how then maybe you will be educated enough to even begin to ask questions
