Results 21 to 40 of 89
11-04-2019, 12:32 PM #21
11-04-2019, 01:02 PM #22
For me the rate is so dependent on the job.
Drill tap is to cheap at $60/hr is a pretty big comment.
- Yes if a guy is tapping a tough alloy in an expensive part that needs a hand tap to get to proper depth...%60/hr is cheap.
- load up 50 pcs alum pieces in a fixture, lock in vise hit start while removing and loading the second fixture to replace when prior cycle is done and being able to load another machine or two without breaking a sweat, little wear on machines and tool, easy setup, simple for any operator on an older machine with customers materail...$60/hr is not a bad number.
-super critical angle and tolerance in unubtanium...$60/hr is not going to cut it.
11-04-2019, 01:06 PM #23
11-04-2019, 01:08 PM #24
IS it the skilled labor or the work that is produced that should set the rate.
I had a job a few years back were I needed MIG welding...simple welds. A guy came in certification up the ying yang...while great to have, the welds only paid $5,00 each and only so many can be done in an hour. I was doing plenty fine with the two guys I had taught to weld a couple days earlier.
11-04-2019, 01:10 PM #25
For me, the roof over the machines has been the most expensive part.
Thanks to the pot industry for driving the cost of prime rural manufacturing real estate and rental rates through the fucking roof.
The pot industry is crashing full speed into the mountain currently though so I guess that's one good thing.
SND liked this post
11-04-2019, 01:18 PM #26
Good question. I'd say it hinges upon the work produced because that dictates skill required and rates charged. If I need a 165t crane and they only have a 250t in the yard, they bill me the 165t rate despite actually sending the 250t unit and we both win. Their crane isn't idle and I'm not paying unduly.
In both examples it's frustrating to have a more highly valued asset doing less valuable work, but it's better than the alternatives in my opinion.
Also- that's the billable rate as shop owner, not what you're paying the laborer.
11-04-2019, 04:32 PM #27
aj liked this post
11-04-2019, 05:11 PM #28
Man, making me feel bad now. My primary job is building and servicing sewer inspection equipment. Sometimes it comes back full of fecal ick. Lol. And plumbers may charge big dough but they sure as heck don't want to pay.
Sent from my SM-G950U using Tapatalk
11-04-2019, 06:35 PM #29
Haas pumping out how many machines each year ?
And going into Ma & Pa 2 car garage backyard shops....all in the "race to the bottom"
Easy fix, Wear a Condom next time.
11-04-2019, 06:36 PM #30
11-04-2019, 06:43 PM #31
11-04-2019, 06:46 PM #32
Yup, the clueless just use mastercam, get a number for runtime, slap $45 per hours
and quote.
Like everyone else does.
I work with a small shop, I explain how he needs to develop different methods, maybe pinch turn (might have to weld up a lathe toolholder for $50)
to "get away from the crowd" and get these jobs. Sneak an extra roughing
cut with a welded toolholder, cut that cycle time.
Keep the machines loaded, re-position the saw, so 20' bars of stock
are not being swung wildly overhead.
Institute piecework, 'cause every time I walk in the shop the minimum wage monkeys are on their phones, the machines are idling, and the red lights are blinking for more stock.
11-04-2019, 06:49 PM #33
11-04-2019, 07:06 PM #34
It all comes down to supply and demand.
When people are starving because of lack of work they will work for less.
Just ask the labor force in China how this works.
Even if skilled there is more supply than demand so prices sit at rock bottom barley able to survive numbers.
Arguably cncs make things less skilled than in the past so the day of all manual machines saw better money.
Bob
11-04-2019, 08:22 PM #35
11-04-2019, 09:10 PM #36
Well if you aren't doing 2D vise work you don't have to participate in that "race."
Not much of a race around here anyway. Everyone is so damn busy, some of my customers will pay 100%+ expedite fees to get something in 2 weeks rather than 4.
Haas pumping out machines doesn't necessarily mean tons of garage shops starting up all over. Plenty of large shops around here buying them 5 or 10 at a time. They're a good value.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
SND liked this post
11-04-2019, 09:19 PM #37
11-04-2019, 09:26 PM #38
I live in a farming county and know a bunch of families that inherited the land- and- "huge profits"? not likely. Of course, you cant compete if you have to buy the land at current prices- but, even with inheriting the land, it costs a LOT of money to farm these days. A single blueberry harvesting machine is $200k or so- my neighbors have 3 or 4, plus a fleet of trucks, a dozen tractors, and a few tens of thousands of square feet of barns- not to mention thousands of packing trays, conveyor belts, packaging machinery, and so on- and, at 300 or 400 acres of blueberries, its not much more than a hobby busienss, in terms of income, most years. Other neighbors of mine grow high end potatos, and get maybe 15,000 pounds per acre- and farming a thousand acres of that is a really tight business, with no guarantee of profit.
More and more, we are seeing mostly foreign investors buying thousands of acres at a time, and not really expecting to "make a living", more like park money away from dictators or higher taxes abroad. One of the big recepients of Trump subsidies to make up for chinese tariffs was a brazilian company- not a family farm. And, curiously, a bunch of congressmen get big farm subsidies too. Mapping The U.S. Farm Subsidy $1M Club
Farming is even harder not to go broke in than machining.
I would propose that one of the reasons small machine shops cant bill very high is because they are still in the 19th century job shop piecework mode, which was a system designed by big corporations. If you arent adding value, and selling that value, rather than a bit of processing on a piece of metal, you are never gonna get ahead.
Especially as a general purpose job shop.
I have known a few very specialized shops- say, a shop that only worked with machining ceramics, or one that did medical titanium- but just making parts is a real tough row to hoe.
11-04-2019, 09:31 PM #39
11-04-2019, 09:32 PM #40
