markz528
Hot Rolled
- Sep 25, 2012
- Cincinnati
I have an Atrump BT30 CNC mill. I bought it new and have been running it for about 18 months now. It does not get a lot of use as it only supports a drag racing operation and I bought it because it fits my needs well.
The more I learn about the machine the less impressed I am. Factory support is poor but my dealer is trying hard - I like him. But now it is what it is.
I had to remove the spindle to correct some issues.
I was very surprised to find what I would call significant nicks in my taper. My questions are what is causing this and how best to clean up? I don't want to make it worse. At this point I am not seeing any ill effects on tool holder tapers.
- Am I inserting the tool incorrectly? I made some corrections and it seems to be engaging better than it used to.
- Do I need to round the ends of the tool holders to make sure they are not sharp?
- Is my spindle too soft? Does not seem to be very hard. How hard should they be?
- Other?
I was thinking of running it at a fairly low speed once back together and hitting it with some emory cloth to knock the high spots off. Good idea? Bad idea?
In addition, I stripped the thread on the draw bar. It has an air operated draw bar. Poor draw bar quality or could something else be going on? I have the air pressure set at 60 psi so I do not think I am over tightening it. Thoughts?
- Other?
