Adding Wifi in Brother with C00 control is easy
You'll need one of these:
Amazon.com: TP-Link N3 Wireless Wi-Fi Nano Travel Router with Range Extender/Access Point/Client/Bridge Modes (TL-WR82N): Computers & Accessories
There is an ethernet and USB port in the control cabinet. You can use the USB port to power it. You'll need to configure it on a desktop or laptop, plugging into a USB. Then you can use the FREE! Brother communications software to drag-n=drop file in or out of the machine. It does require some easy configuration in the control through the data bank. If you want to be able to delete files from the WiFi you'll also have to enable that in the machine control.
$30 and an hour or less. What's not to like? After the first one it's just a few minutes each.
