Will a 115 kva generator power an 80HP (65kva) CNC lathe?
Results 1 to 19 of 19
    Oct 2009
    Oregon
    4,127
    4436
    2079
    Default Will a 115 kva generator power an 80HP (65kva) CNC lathe?
    Thinking about picking up a newer diesel generator to back up my shop. If it will run my biggest machine I will buy it.
    Dec 2012
    AUSTRALIA
    1,993
    9
    609
    Yes,easily.
    Virginia
    26,686
    7561
    8352
    Quote Originally Posted by Garwood View Post
    Slight overkill if it were for 24 X 7 X 365 no-grid operation. Steady load @ 75% is about the sweetest spot for the best tradeoff between fuel economy and wear amortization for best life-cycle cost.
    Biggest machine will usually run well below its max, hence I call it overkill.
    That said, an emergency or backup SHOULD err on the side of reserve power. The machine designed for is not likely to be the only load. Your useful life before major overhaul expectation is multiple years longer [1]. Loads are more likely to increase than diminish.
    2C and "many" used-up gen-sets worth.
    [1] Consolidated Electric 100 KVA. Marathon head, Continental Diesel inline 6, ~ 147 BHP. Typically 3 months before major overhaul pulling a 100 HP motor, no clutch to the compressor & other loads per-each of an "A2" liquid Oxygen plant run 24 X 6, all year @ 85 KVA, and about as steady-state as loads ever get.
    I hope Continental is out of business. The f**kers worked HARD to earn it.
    Buda, Waukesha/Hercules/Hollingsworth, Murphy, Caterpiggle, even screaming-meemie "DEE DEE" hand grenade or make-you-think-they-are-about-to-be had longer lives by far.
    Oct 2009
    Oregon
    4,127
    4436
    2079
    Roughing 1018 with cnmg 632's I can run 80% load for about 20 minutes at a time. Spindle startup with a 300 lb 16" Chuck and 200 lb part is pretty aggressive.
    No gearbox, belt drive spindle, 0-3500 rpm
    Virginia
    26,686
    7561
    8352
    Diesel actually LIKE a decent load on 'em. Look up "wet stacking" and why a turbo Diesel can often be a better deal than normally-aspirated.
    Startup was our biggest issue with the A2 plants, but only once a week. Dry board about a foot long, operator standing on a 5T truck tire, sheet of plywood atop, would push the breaker up with the board. It would trip, first 2 or 3 goes, underslung trailer under the 100 KVA would bounce, try to lift a wheel!
    The main load on the 100 HP (416 Wye) motor was a directly-belted Chicago-Pneumatic PB-44 four-stage air compressor. A mere 120CFM. At 3,600 PSIG.
    Once online, add 40 Ton Worthington reefer, 20 HP motor, then 5 HP caustic pump. Around 16 hours in, Vietnam's ambient temperatures, add a 5 HP Lox pump to fill cylinders.
    You aren't (yet) in need of being set-up for field-mobile, tactical deployment, designed to prep Oxidizer for "Redstone" missiles, or (A1 plant) produce breathing oxygen to support forward-based USAF sorties, so will have a proper disconnect.
    War isn't just "Hell". Sometimes it is a tad weird as well.
    Young USAF Major, Bien Hoa AFB, driving around in a midnight-blue Chevie SS 396 El Camino lady-boy let's-pretend I'm a pick-up truck, Wide-oval redstripe Uniroyals.
    Why TF was HE so privileged, land of the shabby M-151 alleged-Jeep or local Lambretta Franken-scooter tricyle bus and cargo trucks?
    Answer came one day when I was over to Base Fuels cadging a coupla tons of LOX the USAF was kind enough to make surplus to breathing needs.
    There he sat, approach end of the runway with a carpet padded pipe rack in the bed of the El Camino, radio headset on.
    On radio cue, he revs up, dumps clutch, lays smoke and screaming rubber Hell down the empty runway.
    He perfectly matches speed to the incoming U2 spylane, silent as death in cotton wool, by comparison the usual birds on that patch. U2 gently lays one no-wheels wing across the padded rack as they come slowly to a halt as if welded together.
    Haul the wheels dropped on take-off outta the bed, re-attach, regular "tug" takes over, and done.
    Major prolly pulled rank on an Airman First to GET that damned job!
    And here I were, now and then as OD having to run 8 miles of guard posts in a Ten Ton tactical tractor, bobtail, for lack of a single ignorant jeep, spare.
    One thing for sure. That big V8 Diesel going painfully up through the gears jest to git to a dog-trot?
    Never had to worry I'd come up on a pair of guards both ASLEEP!
  6. Likes cyanidekid liked this post
    Mar 2012
    Geilenkirchen, Germany
    2,322
    1404
    1192
    No problem, it will easily handle your load(s) with reserve.
    Jun 2015
    CANADA
    Ontario
    409
    956
    242
    It's not just about size, make sure that power is clean and smooth. Especially when the load changes.
    Don't just take the generator salesman's word for it.
    If there's a problem he is completely off the hook.
    Make sure that the CNC manufacturer agrees and supports it.
  9. #8
    Nov 2008
    Madera county california usa
    2,407
    21
    596
    What happens during switchover?
    Many folks assume generator is everything but not so.
    A client has 40 kw unit that somehow will not support a 4 ton hvac, all new equipment.
    Takes time to spool up to speed after start then after voltage and frequency correct it switches line.
    Usually in 30 seconds or so but a running machine looking primary power may not like that much.
    High power ups one item.
    Or do they have system in machine like ups that retains exact spot in program upon loss of power?
    When power drops the tool stops in place, does it crash or does machine back off as it spins down?
    We know nothing of the machines but backup power a fair bit.
    First call should be as others suggested, to manufacturer to confirm how to design system.
  10. #9
    Virginia
    26,686
    7561
    8352
    Quote Originally Posted by Tony Quiring View Post
    I don't see Garwood planning a gen set even for automatic transfer, let alone UPS-SEAMLESS transition, a whole 'nuther level wanting flywheel or battery bank.
    My take is that he would be planning in advance whether to bring up the machine on Diesel or mains and stay there until making another deliberate choice, all "manually", shut-down, later restart most of all.
  11. Likes Scruffy887, Ox, digger doug liked this post
  12. #10
    Dec 2012
    Se Ma USA
    1,480
    115
    836
    Yup, not a job for an automatic transfer switch. Unless it is mandatory for all employees to drive a Tesla and all have their own charging setup at the plant and all are wired to backfeed the machines.
  13. #11
    Virginia
    26,686
    7561
    8352
    Quote Originally Posted by Scruffy887 View Post
    Ah, well.. Telco pensioner & critical Fortune 100, 400, etc, nailed-up private networks as paid it, here.
    "No break" // UPS power is a whole 'nuther level.
    Hong Kong has the luxury (or curse) of two independent power cos'. Needless to say, more than a few of our data centre facilities are intentionally sited along their service boundaries. Separate entrances, opposite sides of the building, etc.
    We can - and do - get two mains suppliers, then two sets of diesels, EACH, and as many as four separate battery banks and monster UPS rigs, a single site.
    "Needless to say" the only unplanned, not seamless cutover, outage my Hong Kong servers ever had was from human error.
    A rack monkey did the manual redundancy maintenance cutover bass-ackwards to procedure, the rack zone we were in. Killed-off a record attempt at "longest up time" at right around a mere thousand days in.
    Not yet that close to the record. You'd have to know *BSD Unix on an underclocked Via C6 run fanless?
    BFD. That server was only running the attempt for the fun in it.
    But the Finance industry is what Hong Kong is about... so my old mates over to HSBC and Standard Chartered, Wing Lung, & c. were far more seriously pissed-off!
    "New China News Agency" which is "none of the above", as to their real function, wudda had their stealthy ears go deef too.
    Buggers have had one or more servers in every facility on every wire in all of Asia since at least the first term of Slick Willie Cunton.
    BFD. Easier for others to know whom listen to as well!
    You'd have to know humans and the games that they play...
    i i i i i
  14. #12
    Aug 2002
    West Unity, Ohio
    25,213
    5486
    7923
    WOW!
    80HP with a 16" chuck and no gearbox!
    That's a combination!
    Think Snow Eh!
    Ox
  15. Likes SND liked this post
  16. #13
    Jan 2003
    Canada
    11,203
    5272
    3355
    I really wonder what brand and model of CNC lathe that is.
  17. #14
    Nov 2014
    Florida
    3,593
    1507
    1692
    Quote Originally Posted by SND View Post
    Me 3! I think our blanchard was 50hp? and the motor was biggest part of machine almost... 80hp!!!
  18. #15
    Virginia
    26,686
    7561
    8352
    With Garwood's background? Bit of a "hot rodder" ain't he?
    Could be an 1898 Niles Tool Works 120-incher with a Bessemer hot-bulb engine the size of a two-car garage and twice as ugly?
    Oh... and modern CNC controls.
    Conjured up by Ox, of course...
    Ox ever retires to breeding horses, they are like to have wings, tandem saddles, six legs, snow-traks for Antarctic use, and zero-zero visibility automatic landing systems.
    You'd have to know "necessity" and clever Buckeye farm boys' conceptions of amusing ways to earn a crust...
  19. #16
    Jan 2003
    Canada
    11,203
    5272
    3355
    I'd put an Amp clamp on it and see what she draws in I think.
  20. #17
    Virginia
    26,686
    7561
    8352
    80 Hoss? Startup inrush would prolly blow MY Amp-Clamp's tiny little MIND and fry my cellphone from a meter away as well!
    The 100 KVA to the hunnert-hoss motor on the Oxygen plants would surely mess-up a mechanical watch of the era..
  21. #18
    Oct 2005
    14,816
    Might say "J&L" on the front of the headstock......Or "W&S"
  22. #19
    Oct 2009
    Oregon
    4,127
    4436
    2079
    It's a Leadwell LTC-30 something or other. Motor says 65KW on it and it's the size of a small refrigerator laid on it's side. Standard was 40HP, but this one was ordered with extra oomph I guess. I don't know.
    I wouldn't be switching automatically. No way.
    I'm on a phase converter now and can barely run this lathe. I need to do a big power upgrade soon, but in order to do that my shop will be down for probably a few weeks at the minimum. All my machines run on a busway system so I was figgering I could run the generator into the far end of the busway and pull the fuses from the existing panel to run on gen power.
    I just realized I wrote 65 KVA in the title instead of 65KW. Probably not too far off from one another, but it's 65KW spindle plus the hydraulics, control, servos and live tooling.
    I think the generator I'm looking at will cover at. It's a newer Deere with a 6.8L inline 6
  23. Likes Ox liked this post
