Will a 115 kva generator power an 80HP (65kva) CNC lathe? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21
    Oct 2013
    New Jersey
    1,112
    946
    A softstart could be a lower cost option over a VFD. We used softstarts on all pumps 10 hp and up to keep the pressure surges from damaging the membrane systems we built. I personally have done installations up to 150 hp. They are very compact, only a little bigger than a contactor. Once motor is at full speed a mechanical contactor jumps out the semiconductor switch. The mechanical contactor see no arcing or starting currents so it can be very tiny, and there is no power loss.
  2. #22
    Jul 2006
    Arizona
    4,609
    18489
    4331
    Quote Originally Posted by garyhlucas View Post
    The OP is talking about a CNC lathe with a VFD--not a manual lathe.
    I installed a soft start on my 15 hp manual turret lathe so the inrush wouldn't kick out my CNC lathe if I was using them at the same time.
