Our Mitsubishi HMC [MPA 80A] has a Top mounted ATC unit [BT-50] that moves between the Spindle and Magazine for Tool Change. The Horizontal movement is on THK NSR 30 TSB LM Rails, which run on Re-circulating Roller Ball Block. The vertical movement for Tool Change runs on THK NSR-20 TSB Rails, similar blocks. Both the units have a semi-circular block [LBS 30 and LBS 20], not the usual rectangular block, The THK dealer is surprised with this arrangement. The Wipers are NSR 30 & 20 respectively.
For the NSR-20 [Vertical Movement], I have replaced the roller block with an Aluminum-Bronze block wirecut to the same profile, to give it a sliding fit, this arrangement has worked fine for the last 6 years. now i need to replace the Wipers, but THK don't sell these wipers separately now.
can any of you advice me on this. how to make the rubber profile on wiper.
looking forward to any advice on this.
thank you all in advance.
