This.
It is because doing what you describe will save you
nothing. More oft than not, it causes trouble. WEDM
_can_ work that way, but most of the time it likes for the wire to have material surrounding it. This creates a stable arc zone and also aids in flushing. Both are prerequisite for high accuracy
as well as speed,
believe it or not.
Go outside and grab your garden hose. Walk over to the corner of your house. Turn the hose on full blast and aim it at the edge of the corner of house.
What happened?
Yep.
It deflected away, shooting off to the side. Same thing happens in WEDM. This creates an area of instability for both the wire, and the arc, not to mention the flushing jet. So, things slow down to adjust for it. And it often leaves a shitty cut.
In the end, one still needs to get it clean enough and accurate enough to perform skim ( finishing ) cuts. So milling out the pocket saved you absolutely zero and more likely caused you time, effort, and grief.
I have seen wonderfully performing operations turned to shit because someone unfamiliar with the realities of the job thought that it was "too slow" to be correct and that surely, "...it can be improved upon and sped up."
WEDM takes time. It is a snail on thorazine. But it is a deadly accurate snail that can do things no other can.
I learned a long time ago to pay attention to the REAL things that affect speed and performance. Maintenance, consumables, and educated strategy. Don't cut corners. Don't pass "Go!" Do it right and collect much more than $200.00.
