Ox
- Aug 27, 2002
- Northwest Ohio
1990 Mits Meldas
(are all Mits called Meldas?)
Machine has a hydro actuated sub-spidle for the linear axis. For the FWD direction it simply does a [semi] controlled crash into the rear turret. Amazingly enough - it seems to hold +/- .001 for the most part.
I have already used it to pull the bar, but I was pulling it all the way HOME.
I haven't used this machine all that much, and the sub even less as it aint the most user friendly set-up as comapared to a ball screw driven unit, but I am gitting more comfy with it and am dooing other things to the machine to make it more Ox freindly as well.
So today I was playing with it a bit. After having good luck with the pull HOME routine, and how well it repeated, I wanted to see what else I could doo with it that at first I would have guessed NOT.
Well - my first guess was right....
Once the sub has crashed, sub col closed, main open - I tried to doo a G1 Z+ on the rear turret to move the sub back W amount. It faults out and up pops the error code #223. "Machining Impossible [you bloody moron, you left the] Headstock collet open!"
Well - since I ain too sure how to pull with the sub w/o the collet open ....
So - Jist fer grins - I tried G0. That is not a feed code and thus may not trip the "Machining" threshold. ??? However - I can only imagine how well this will work!
Well - yep - she moved! Much faster than prefered, but she moved! And it scared the axis drive as much as it did me! (tripped out (easilly?) ) As well - that much speed (keep in mind this is likely only 400IPM) will ilkely "unseat" the sub from the rear turret when it stops anyway - tripping yet another alarm.
I have looked through all 18 macros and find nothing in there that even has error code text at all like I have seen in some other macros on Fanucs. So I am figgering that it is in the ladder. ???
While I don't want the prog to start if the main collet is open, but it would be swell if I could edit the ladder to allow it to doo a G1 with it open.
No idea if it would be possible to even make a werk-around in a macro for this?
Another option that I have thought about while keying this all in - would there be eny way to code into the prog to shut down the RAPIDS? I would think that if I could set the rapids to 25% and run with the G0 - that it should werk perfectly! and then speed it right back up aggin...
Actually - I really like that idea. That sounds like it should werk and seems like it would be pretty easy to code in. .... somehow....
Anyone know how?
FWIW - the RAPIDS is on a soft key as opposed to a mechanical switch. As a rule I hate this, but in this instance that may make life easier. ???
BTW - I [don't think that] I have access to see the ladder, and I ass_u_me that this is a burnt PROM chip? This machine was DOA when we got it and we had to load everything. But I don't find a ladder in any of the code. I know that even a dead battery won't lose the ladder on a Fanuc, so .... ????
Think Snow Eh!
Ox
Anyone know how?
Think Snow Eh!
Ox
