I am setting up my first "production" job that will be a repeat in my shop. I've been a tool maker my whole life and while I have worked in some BIG production facilities, I avoided the production side like the plague.
A little bit of an outline of the job, then a few questions about opinion on setup.
Job as I have it setup was going to be 5 work coordinates. I decided to condense the last three setups into a fixture, which I *hope* will work. Going to cut it and try it out today. This seems like a simpler approach to cutting 3 sets of soft jaws. If everything goes to plan I will make two of the fixtures so I can pull one out to do my changeover while the other is running.
I am trying to be proactive for this job because it should re run in a few months (3-6mo) The job is small, 60pcs, but the parts are fairly high complexity with several features that are close tolerance, and several "aesthetic" requirements.
My question in relation to the fixture. As I program the parts, I am going to need adjustability to get them tweaked into my OCD level of perfection. I am trying to decide, long term, do you think it would be better to program each part with its own work coordinate, or use the same work coordinate(fixture)? I lose some flexibility with doing 1 work coordinate, though that flexibility may not be needed.
In regards to the offsets, when I dial these parts in, I am trying to decide whether or not to use the control or offset in CAM. This job uses MOST of my tool holders, and a ridiculous amount ($$$) of tooling, so I do not ever see myself having dedicated tooling for the job. If I program the offsets in CAM, they are retained for the next run, I don't have to worry about documenting them. They will of course vary some run to run, but hopefully I can get it dialed in close to where first piece should be good?
