01-13-2021, 09:03 AM #1
Would anybody like to beta test a rechargeable battery system for Renishaw OTS probes
Visited a friends shop in late 2019 and saw all the 1/2 AA batteries from their probes that they discard in a year. They get approx 6 months out of a pair and less if the machine is lights out (more tool probing). With 48 mills they go through about 250 batteries a year on just the table probes alone.
This seemed like a waste of money, material, etc. so I created a rechargeable battery system for the 1/2 AA OTS probes. It screws into the back of the OTS probe in place of the battery cover and provides power via a single rechargeable li-ion battery. You should see no difference in use from the 1/2 AA batteries, it even signals the probe when the battery is low so that the low battery lights on the OTS and OMI/OMM work as they should. If you forget to charge the battery in time, 10 minutes on a charger and you are good to go for the rest of the day and maybe more, no more scrambling to overnight ship a few batteries with a machine down.
I have a few beta units remaining so let me know if you are interested. Please note that the beta units that remain have some cosmetic issues (spots on the anodizing and things like that) but they are all fully functional, batteries included.
01-13-2021, 09:27 AM #2
What size Li-Ion battery does it use and what do you need to recharge it?
01-13-2021, 09:32 AM #3
01-13-2021, 09:37 AM #4
It actually uses a 21700 battery but you can find a charger for under $10 from the usual places. I prefer the vapcell s4, usually about $35 but well worth the extra.
01-13-2021, 12:47 PM #5
If 10 minutes on a charger gets you through the rest of the day, how long does a full charge get your friend running lights out? How does the life of this setup compare to that of running the standard batteries?
01-13-2021, 12:59 PM #6
This is a neat idea, but why TF would a shop with 48 mills continue to buy them with the stupid 1/2AA size probes? The full AA size OTS is a direct swap...
The full size system is also a lot smaller than this, and lasts months running 24/7 in our environment with tool breakage running on every tool.
Seems like a creative solution to a problem that shouldn't really exist.
PROBE liked this post
01-13-2021, 04:18 PM #7
Sorry I was not clear, when I said "you should see no difference" between this and the standard batteries I meant the runtime of the OTS will be same with this set up as with the 1/2aa. So if you get about 6 months with your 1/2aa batteries you will get about 6 months with this. My friend gets about 2 months running lights out with the 1/2aa batteries and about the same with the rechargeables.
When it comes to lithium derived batteries there is about a 4x difference in energy density in single use vs rechargeable batteries so you need to increase the size of the battery to compensate, there are also some other differences like output voltages that you need to contend with.
01-13-2021, 04:53 PM #8
why does anybody need a wireless probe? Pallets?
lumley32 liked this post
01-13-2021, 04:58 PM #9
Dare I say most moving table machines have wireless tool probes? Certainly most new machines from the big builders.
One less thing to deal with. The optical interface is already there for the spindle probe, so might as well use it. Plus some of us like to move it to a new spot (or yank it off the table) from time-to-time.
mhajicek liked this post
01-13-2021, 05:51 PM #10
I'd search for AS9100.
He has been quite the beta tester in the past.
Think Snow Eh!
Ox
01-14-2021, 03:30 AM #11
It is quite amazing, that Renishaw are still "pumping" the OTS1/2AA product. The lithium 1/2AA batteries are expensive, difficult to find, and not all off them can work with the device (just see the proper battery type "bulletin" attached to operation manual). The newer OTSAA does the same job, using not restricted, widely available cheap batteries. So why not to discard the older product. Maybe the words "sorry, we've made a mistake" do not exist in their vocabulary.
01-14-2021, 06:44 AM #12
Unfortunately there is not always a choice as to what size OTS you get, it is usually up to the machine tool builder. AFAIK the AA size OTS is not an option for Haas machines (certainly was not for me) and swapping it out after the purchase is approx $2500.
I think the biggest problem is that even if you are using the 1/2AA or the AA version they are still single use batteries which seems like such a waste given the li-ion rechargeable options that we have today. Single use batteries end up costing more and creating more waste than something like this. When I looked into it, even with my very modest production I spend about $65 per milling machine per year on single use batteries and dispose of at least 9 batteries per mill per year.
01-14-2021, 08:25 AM #13
I like this idea, good luck with it.
We only have one OTS probe here, it uses the 1/2aa batteries, and it doesn't get a lot of use compared to you 24/7 people.
Still, every time I swap out the batteries I think "what a waste."
There's no reason the table probe on a little DT-1 can't be wired to avoid this.
Pathogen liked this post
01-14-2021, 12:04 PM #14
We haven't bought (or thrown away) AA or AAA batteries in years. Quite a while back I bought about 40 of these in bulk packs and a charger, then put them in one of the consumables drawers in the tool crib. IIRC they have more capacity than normal single-use batteries as well.
https://www.amazon.com/Panasonic-BK-...NsaWNrPXRydWU=
pb1 liked this post
