Hi,
I added few lines at the start and end of my nc file to calculate and store actual cutting time (refer attachment) in a common variable (e.g. #520). I wonder is there any macro or gcode command to write value of this variable to the end of my nc file? As I am looking for solution to record actual cutting time without setting up complex data integration between CNC machines and computer. My machines use Fanuc and Heidenhain controller
Thank you
Thank you
