WTF is this motion under heavy load? - Page 2
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 21 to 40 of 141
  1. #21
    Oct 2007
    SPAIN
    3,669
    2083
    1372
    Quote Originally Posted by jz79 View Post
    this is supposedly what it looks like:
    Attachment 267532
    I'm not very experienced with this, but I wouldn't call that a shit design...
    On a machine of this size, and cost, the LAST thing I'd expect to see is an axis "floating" about.
    It's a high torque spindle - but what's the point of that if you can't use it (rigid tapping 2" pipe threads? )
    Cutters of that diameter should snap like a carrot long before the axis should be bouncing around.
    If I was DMG, I'd be putting a video out this morning with a short stubby holder etc to try and clear my name...
  2. #22
    Jul 2006
    Hillsboro, New Hampshire
    7,848
    1836
    5519
    Attachment 267532
    I'm just an amateur (hack) machine/mechanical designer, but to me that Y/Z casting looks very light, as if designed for HSM and not roughing as was shown in the video. I could easily see that thin wall casting deflecting and allowing a torsion displacement of the cutter, in line with what barbter mentions in #19.
    I couldn't tell if there was movement at the toolholder/spindle interface, my guess is casting twisting and perhaps the spindle and Z axis ways deflecting a bit too. But I'd blame the casting for most of the uncontrolled movement.
  3. Likes barbter liked this post
  4. #23
    Dec 2011
    329
    44
    163
    Quote Originally Posted by barbter View Post
    It's a 12,000 lb machine.
    Who said anything about high torque? HSK63 and high torque is an oxymoron.
    The cut was clearly outside of the design parameters of the machine.
  5. #24
    Dec 2011
    329
    44
    163
    Quote Originally Posted by gregormarwick View Post
    If that was a 40 taper that would have gone south very quick. Dual contact and high retention force is what kept that from detonating.
    HSK is not more rigid than the equivalent 40 or 50 taper. It simply does better at high speed.
    Higher drawbar force doesn't make up for the thin walls and the short taper.
  6. #25
    Feb 2007
    Aberdeen, UK
    3,666
    1264
    1432
    Quote Originally Posted by Radar987 View Post
    Sandvik published a study years ago where they tested the load deflection rates of various spindle interfaces. The purpose was obviously to show how wonderful capto was, but the difference between HSK and dual contact steep taper was surprising, and the difference between HSK and plain steep taper was massive.
  7. Likes CNC Hacker liked this post
  8. #26
    May 2019
    575
    151
    223
    At quick glance it looks like tool holder deflection but I've learned modern videos can be very unreliable due to the image stabilization crap. I've taken several videos where at first the spindle appears to be moving in the X and Y axis when it is not. I'm not a video guy but I'm going to assume when the camera senses movement of a large section of the frame it assumes that is because the camera is unsteady and moves a smaller part of the frame instead. This can make for some pretty funky looking videos.
    There is obviously something bad going on and that cut is beyond the capabilities of that setup, but all I am saying is the video can't be used to make an accurate determination of where the flex/distortion is coming from because we don't know what kind of new fangled digital processing stuff was used. If a proper high speed camera with an independent datum in frame was used I would give some credit to video analysis. IMO
  9. #27
    Nov 2006
    Jupiter, Florida
    256
    207
    17
    Interesting. I couldn't figure out what the motion was. Didn't really look like flexing to me but I couldn't come up with another answer. That camera stabilization or frame rate idea didn't occur to me.
    Thanks Hardplates
  10. #28
    Oct 2007
    SPAIN
    3,669
    2083
    1372
    Quote Originally Posted by Chris59 View Post
    Thanks Hardplates
    I agree that Hardplates makes a very valid point.
    But if it isn't flexing (or mechanical shock), what's causing the floor finish and why is it better the closer the Y (Ram) goes back into the main casting...
  11. #29
    Dec 2011
    329
    44
    163
    I take anything Sandvik publishes with a grain of salt.
    It's been discussed here on a few occasions that for low speed hogging, it's hard to beat good old 7/24 tapers. Real world experiences from people with both types of spindles, not some dudes running around in yellow lab coats.
  12. Likes Oldwrench liked this post
  13. #30
    Feb 2007
    Aberdeen, UK
    3,666
    1264
    1432
    Quote Originally Posted by Hardplates View Post
    Image stabilization as you describe it is how youtube did it years ago, it was absolutely horrible - motion sickness inducing, and caused terrible image distortion.
    Modern digital stabilization works very differently (moves the whole frame uniformly around temporal datum points, and then crops the edges).
    Even higher end phones have mechanical stabilisation in the lenses anyway these days.
    I doubt that image stabilisation is at play here in any meaningful way.
  14. #31
    Feb 2007
    Aberdeen, UK
    3,666
    1264
    1432
    I admittedly don't have much experience with HSK.
    I do have a lot of experience with 50 taper, and I do have a lot of experience with capto, and I do have a lot of experience with heavy machining.
    Capto beats steep taper hands down, and not necessarily even in the equivalent size. C8 is closest to 50 taper dimensionally, but even C6 is stiffer.
    Capto and HSK have very similar retention forces, similar taper angle, and are both dual contact. So I have no reason whatsoever to doubt sandvik's study.
  15. #32
    Nov 2006
    Jupiter, Florida
    256
    207
    17
    Another interesting point. Still unsure. Perhaps the tool was sharp initially and gouged the bottom til it self honed under the insane cut? Usually when I see flexing it's in one direction. Fascinating subject though. Thanks
  16. #33
    Nov 2006
    Jupiter, Florida
    256
    207
    17
    I watched a youtube video about frame rate with propellers. You get very odd results. I wonder if this is part of the problem?
  17. #34
    May 2019
    575
    151
    223
    Something is definitely moving and not right. All I am saying is I don't think that video is useful for analyzing anything beyond "somethings not right here"
    That being said the fact it crops the edges would seem to me like it would be more capable of hiding its foolery. As I said I am not a "cameraman" but I do know that best way to analyze something is to begin with removing as many potential variables as possible. I would consider a reality TV video a variable and not reliable scientific evidence. IMO
  18. #35
    Feb 2007
    Aberdeen, UK
    3,666
    1264
    1432
    That's due to the "rolling shutter" capture method.
    About the only artifact that might be encountered in this kind of scene from that would be some horizontal shearing, but nothing here is really moving fast enough.
  19. #36
    Jan 2014
    Temecula, Ca
    2,982
    1316
    3846
    "Harvey 3 is six flutes" and he holds up 5 fingers. What a clown
  20. Likes lumley32 liked this post
  21. #37
    Mar 2017
    LATVIA
    389
    94
    202
    Attachment 267532
    I'm in the same amateur category, so it is just speculation on my part
    interesting that in the picture I linked earlier, 3rd gen DMU 50 (which seems to be the one in the video), the Y/Z casting is quite a bit wider than in the 2nd gen machine, indicating that there was a need to beef it up
    and then there is the case of linear guides, which don't transmit vibration as well as box ways, meaning that the X/Z casting may have started to oscillate because it couldn't pass the vibration down to the rest of machine effectively enough
    here is a pic of a bare 2nd gen, note how narrow the Y/Z casting is:
  22. #38
    Jan 2019
    SWEDEN
    196
    57
    24
    about the cutter, app chart says Fz ~0.10mm (0.12-20%) at 1.25xD, and he did 2.50xD at same Fz, it survived, but how long would it last?
    Long enough to make the video, I guess that's all that counts?
  23. #39
    May 2019
    575
    151
    223
    Quote Originally Posted by Larry Dickman View Post
    Does the Harvi6 have 3 flutes? Lol
    Sent from my moto g(6) using Tapatalk
  24. #40
    Aug 2010
    Connecticut
    1,920
    1485
    2034
    I don't watch Titans stuff, not really interesting to me. His stuff is almost like any "reality" based programming, drama must be added to interest viewers. I'm interested in machining, not drama.
    That being said...It looks to me like he was promoting an endmill, not a machine. Regardless of what's going on there, it is impressive that the endmill didn't blow up, and it took some serious cuts/abuse.
    It does say something about the product, and I think that was the message he was trying to convey.
    The video has people talking, mission accomplished.
  25. Likes cameraman, mhajicek liked this post
