Anybody have an idea why when i trief to move the y axis on our doosan 5700 it just zoomed to the back and crashed?
Machine parameters did get reset but that would not explain why the machine moved so fast with one touch of the y jog button at 25 percent
....Care to explain what was happening so that parameters were lost and had to reset them?
My main concern at the moment is that the speed at which the y axis move. If i can p then move it it might crash the other direction .
Does anyone have the parameter # for adjusting rapid movements on fanuc oi
1420. Be aware that if a hardware problem is the cause this parameter probably will not have any affect on the speed.
The most cautious way to deal with this is to disconnect the motor from the screw. This assumes the machine does not have scales.
I had an older Fanuc, one day it was just sitting there when all of a sudden it just took off in X at full throttle and slammed into the thrust bearing.
Turned out to be a bad bridge rectifier on the power supply board.
Notice
