Your favorite turning insert
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    May 2019
    Michigan
    1,481
    426
    680
    Default Your favorite turning insert
    I used to run Seco's TP2501 grade in CNMG432 turning low-alloy steel, recently switched to Ingersoll's TT8125 grade with similar tool life at just over half the price. Is there someone else I should be trying? What is your go-to brand/grade for steels?
    Feb 2018
    DENMARK
    209
    12
    139
    Been using sangvik cnmg and vbmt but trying out the garant inserts slowly.
    Sendt fra min EML-L29 med Tapatalk
    Nov 2013
    Utah
    4,891
    1294
    2765
    Whoever has what I need, when I need it. Turning insert could cover the light side of the Moon. I'm not going to sift through all Billion of them to find the cheapest one. I just don't have the extra time.
    R
    May 2008
    SOUTH AFRICA
    1,636
    1211
    672
    I used to mainly use Iscar but the past few years have been trying out others because of how high their prices have gone. So Mitsubishi make some great stuff, particularly their threading inserts, Seco have some good stuff but Walter are top notch on their Titex range of ISO inserts. Not cheap but kick butt. Sandvik I have used but they are also pretty pricey over here.
    May 2002
    South Central PA
    13,891
    2434
    3679
    Iscar WNMG 432 TF in 9250 for just about everything except heavy roughing, WNMX in 9250 for when the WNMG insert breaks.
    Jan 2017
    Oregon
    3,624
    768
    2508
    Seems like whenever I find a grade I really like, it gets discontinued.
    WNMG and VNMG most used for me.
    My favorite GP grade is Kennametal KC935, when I can find'em on ebay I grab'em.
    May 2019
    Michigan
    1,481
    426
    680
    Thought I'd give an update of my adventures.
    I just got done doing some A-36 with a laser cut hole in the center.
    (Nasty slag and heat-affected zone.)
    Insert was a TPMT 32.51 on a 1" boring bar with
    Seco's TP1501 grade, got 10 parts per edge.
    I got some Ingersoll inserts in this morning
    (TT8115, equivalent grade to Seco).
    They got 19 parts on an edge before biting the dust.
    Oh, and Ingersoll was $9.00 instead of $13.00!
  8. Likes DouglasJRizzo liked this post
  9. #8
    Mar 2012
    Traverse City, MI
    56
    13
    57
    I grab sumitomo usually as first pick, Mitsubishi as second. The new grades from both of those companies have been fantastic in steel/SS/and super alloy and titanium.
  10. #9
    Apr 2015
    AUSTRALIA
    745
    39
    167
    i have not seen this insert for a while since i did my trade and don't recall its name but i can describe it.
    It had a negative tilt to the job but a positive angle to going down to the right and it was a square shape insert with a centre pin holding it in place.
    The thing was awesome for roughing, the feeds and depth it could handle where enough to max out the machine motor on the lathe (10 hp ) and the chips where ripping off in small short curls. It stripped material like it was butter.
    Haven't seen it recently and don't know what happened to the manufacturer but am keeping a eye out for it.
    seen similar designs in Milling cutters just the odd one.
    Pitty its not around, the standard neg rake tool doesn't compare.
  11. #10
    Jun 2011
    New Jersey
    966
    592
    384
    For turning I tend to go either Sandvik or Kennametal. Lately Sandvik.
  12. #11
    May 2019
    846
    274
    388
    I've never understood why people go with CNMG over WNMG unless they are using the 100 degrees sides for heavy roughing. Only reason I even own any CNMG holders and bars is cause I ended up with a bunch of ceramic and CBN CNMG inserts.
    Am I missing something?
  13. #12
    Apr 2019
    Arkansas
    1,301
    571
    494
    Quote Originally Posted by Hardplates View Post
    Right! I think most tool salesmen just push cnmg and vnmg. Maybe their margins are better on cnmg inserts??
    Sent from my Pixel 3 using Tapatalk
  14. #13
    May 2019
    846
    274
    388
    Quote Originally Posted by as9100d View Post
    Maybe not the margins in the insert itself but with 4 vs 6 edges they will sell more.
    I will say the 100 degree edge is fantastic for heavy roughing on a manual, especially if there is nasty scale. But I and most people could get all the used CNMG inserts they want with virgin 100 degree edges for free.
  15. #14
    Nov 2007
    Alabama
    1,545
    184
    284
    If you liked Seco’s Duratomic grades you’ll love this in steels. It’s got a huge sweet spot at less than $4.00 each:
    ZCC CNMG432-PM YBC252
  16. #15
    Nov 2007
    Alabama
    1,545
    184
    284
    Pretty good selection here:
    CARBIDE360.COM LATHE INSERTS
  17. #16
    Sep 2006
    Abingdon, VA
    3,506
    4743
    3348
    Depending on how the pocket in the toolholder is made, WNMG’s can be slightly less reliable in the pocket than a CNMG.
    Better-quality WNMG holders have part of an additional wall to capture the trailing outer edge of the insert, helping to maintain security during cutting.
    No such issues with a CNMG tool holder...
    ToolCat
  18. Likes Hardplates, SND liked this post
  19. #17
    May 2019
    Michigan
    1,481
    426
    680
    CNMG vs. WNMG debates can make Ford/Chevy ones look tame......
    I would go with WNMG but we don't do enough production to justify changing out the inventory. Someday, though.
  20. #18
    May 2016
    Ohio
    593
    171
    193
    Quote Originally Posted by exkenna View Post
    I’m curious do think the Zhuzhou brand inserts hold up against the big names?
  21. Likes as9100d liked this post
  22. #19
    Jun 2019
    421
    133
    382
    We get a lot of use out of our 100 degree holders here for roughing. Mitsubishi inserts treat us well for the most pat.
    For our really heavy roughing we use Iscar's COMG646 in a 100 degree holder. Nothing like taking off about 7/8" off of a diameter per pass. Though they don't like heavy forging scale so you have to be more gentle until you get through it.
  23. #20
    Nov 2007
    Alabama
    1,545
    184
    284
    Quote Originally Posted by Shop Supply Guru View Post
    I've been surprised with the performance. Like any other line, they have 2-3 home-run hitters and the rest are just average.
    YBC252 is rock solid in all carbon steels with a perfect balance of toughness vs. wear resistance. It's stable up to 1100 sfm in low carbon and does not chip easily. I would say it's almost a carbon copy of Seco's TP2500
    The YBG202/YBG205 twins are my mainstays in Stainless and will handle most Hi-temp alloys with the correct chipbreaker. They remind me of IC907
    YBG105 for Inco and other nickel or chrome based alloys. Very similar in performance to KC5010.
    I would like to have a quality domestic brand or a Mits but I'm a one-man show and the big names won't even talk to me. Gotta take what I can get.
