Z axis counter balance noise
Likes Likes:  0
Results 1 to 5 of 5
    Jul 2016
    LITHUANIA
    23
    Default Z axis counter balance noise
    hi,
    I got YCM 106A milling machine. recently i noticed strange sound which i believe comes from Z axis counter balance. I checked it and i found that there is big looseness between weight hole and shaft. This annoying sound only comes when Z axis makes rapid moves for example drilling with chip breaking. Does anybody else have same problem and could help me to solve this problem. How can i fix it?
    Jan 2014
    Washington
    4,099
    768
    2170
    Not sure what that machine has for a counter weight, but on chain hung ones, worn chains and sprockets can cause odd noises and even jerky motion. Particularly if one chain is adjusted poorly or worn/stretched more than the other resulting in the weight hanging crooked.
    Jun 2006
    Thunder Bay Canada
    1,794
    552
    298
    Worth taking a look. Just think about what would happen if the chains broke........
    Jan 2014
    Washington
    4,099
    768
    2170
    I've had to fish a counterweight up from the bottom of a column twice due to broken chains. One of the least enjoyable jobs I've had to do.
    May 2011
    New Jersey
    1,773
    166
    954
    I'd also check and make sure the rice and soy sauce tanks aren't empty...all kinds of funky stuff can happen without it. But I'd get a look at the support system first.
