?? Z Axis Crashed ??
Max Weber
Jun 15, 2017
I have a Sharp 2412 with a fanuc control. It spends most of it's time offline. I had the PSU in the combo drive repaired last year. After about 3 months of the machine being off, I powered it up normally and did a zero reference return (full rapid) and while the Z axis was moving up it felt like it crashed (could feel it in the concrete under my feet) but when I checked it's position it wasn't beyond the home reference position marker. Well the PSU had blown again (overvolting) so I figured it sent an abnormal current to the servo during the zero return and then it went into some kind of failover mode that e-stopped the axis.
So anyways I had to send the PSU back out for repair again, while that's being done I decided to do a full service on the machine. While I'm up on the Z axis replacing the oil metering units, I notice a loose chunk of steel :scratchchin: I immediately think "oh great, something did break after all" I fished it out of there with a magnet and it looks like a physical stop for the z axis?!? I dont see a part for this on the Sharp parts book. My software AND limit switch failed? This is kinda crazy that it appears my Z axis almost shot off the rails... Is this what happened? I can't think of any other scenario. It looks like it was ripped out of the casting of the Z axis servo housing and sheared one of the bolts off... so it was definitely some extreme force. How could this happen? Did my limit switch fail?
See pictures below:
No physical stop like this in parts diagram (previous owner added them in?)...
I just climbed up top of my 2412- nothing like that on my machine.
No holes drilled in the casting either.
I have a 2005 2412 and that block IS on my machine.
Why do these machines have limit switches with absolute encoders. Is the limit switch just there for extra safety.
Now I wonder if they even work.
That's interesting. Mine is a 2005 also. Oi-Mate MB, without absolute encoders.
I'm wondering if the block is to help set the Z limit, and OP's machine lost the APC batteries when it was sitting idle.
Do you have the APC option on your 2412?
yes 6 volt battery backup
Just a guess, but I think the purpose of the block is to set the G28 position. One person at the control, one up top with a feeler gage...
I'm starting to think it failed. The Sharp parts book has it listed as a "popular" replacement part (with a red star next to it)
Update, Sharp says the limit switch likely failed. Going to replace it. Just thought the other sharp owners would want to know.
@Kallam @jancollc do you guys have a picture of your z limit switches? I just pulled the cover plate off of where it's supposedly located in the parts diagram and there's nothing there...
Can you get a picture of the part number and brand name, etc? I called Sharp and they don't have it in stock so I have to try and find it somewhere else.
