Hi
I got a strange issue and can't find out what's the cause.
I have a program which start with facing a part.
First a face and it leaves 0.3mm stock
Then a second facing op which removes everything from the top.
Both ops remove material. And the rest of the program runs.
But when I measure the top of the part to a pocket it's 3.3mm instead of 3,00mm.
I triple checked tool offsets and so on. But offsets are spot on.
Funny thing is when I start the second facing op again which removes the 0,3mm. It removes material and the depth of the pocket is spot on...3,00mm.
But why doesn't the program remove the 0,3mm in the program?
It where long days and I'm a bit tired. But I can't find the issue?
I also checked if the second facing was included in the program. But it is! and it's removing material!
I attached the beginning of the full program and only the facing op, which I run afterwards to correct it.
View attachment program1.txt
View attachment facingop.txt
