Hello, my first post here!
We have the Zund G3 and i was wondering if you can help me with relieve routing.
I have read the HP-GL manual and manage to create a .plt post process file in Autodesk Artcam.
You maybe can take a look of .plt files (I don't know how to attach the files). Our goal is to route 2.5D relieves on forex and acrylic too start with.
I'm also looking for sample files for 2.5D routing in .plt format for the Zund G3 with a RM-A spindle.
I can't find any information anywhere.
Is there a tutorial or guide i can follow?
Can some kind soul help me please.
My questions are:
Can you help me with the software and steeps to send the .plt file to the router under safe conditions? (CAM, command line, communication interface)?
Can you help me in the creation of the tool-path settings?
This is some output information about the tool-pathes:
Relief Dimensions:
Width: 300.00000 mm Height: 300.00000 mm
Min X: -300.00000 mm Min Y: 0.00000 mm
Min Z: 0.28120 mm Max Z: 12.00015 mm
Material Thickness = 12.0000 mm
Z Zero = Bottom of material
Machining Time: 01:40:32
OptiFeed Time: 01:40:32
zund - End Mill 6 mm Roughing
Tool: [1] 6.000 mm dia. slot drill
Feed Rate: 500.000 mm/sec
OptiFeed Min: 500.000 mm/sec
OptiFeed Max: 500.000 mm/sec
Plunge Rate: 50.000 mm/sec
Safe Z: 20.000 mm
Spindle Speed: 40000 r.p.m
Stepover: 2.400 mm
Tolerance: 0.025 mm
Allowance: 0.000 mm
Home Position: X:0.000 Y:0.000 Z:20.000
Comments: zund
Feed Rate Length: 124755.0 mm
Plunge Rate Length: 935 mm
Rapid Rate Length: 9789 mm
Machining Time: 00:19:11
OptiFeed Time: 00:19:11
zund - Ball Nose 3 mm Finishing
Tool: [1] 3.000 mm dia. ball nose
Feed Rate: 200.000 mm/sec
OptiFeed Min: 200.000 mm/sec
OptiFeed Max: 200.000 mm/sec
Safe Z: 20.000 mm
Stepover: 0.300 mm
Tolerance: 0.010 mm
Allowance: 0.000 mm
Comments: zund
Feed Rate Length: 243616.3 mm
Plunge Rate Length: 12 mm
Rapid Rate Length: 392 mm
Machining Time: 01:21:21
OptiFeed Time: 01:21:21
Machining time estimates based on a rapid feedrate
of 0.000 mm/sec and a time scaling factor of 4.00
Thanks in advance
My questions are:
Relief Dimensions:
Safe Z: 20.000 mm
Stepover: 2.400 mm
Tolerance: 0.025 mm
Allowance: 0.000 mm
Comments: zund
Safe Z: 20.000 mm
Stepover: 0.300 mm
Tolerance: 0.010 mm
Allowance: 0.000 mm
Comments: zund
Thanks in advance
