Zund G3 RM-A Artcam
qute
Jun 24, 2019
Hello, my first post here!
We have the G3 and i was wondering if you can help me with relieve routing.
I have read the HP-GL manual and manage to create a .plt post process file in Autodesk Artcam.
You maybe can take a look of the files (don't know how to attach the plt files). Our goal is to route 2.5D relieves on forex and acrylic too start with.
My questions are:
Can you help me with the software and steeps to send the .plt file to the router under safe conditions? (CAM, command line, communication interface)?
Can you help me in the creation of the tool-path settings?
Here is some output of the toolpahs:
Relief Dimensions:
Width: 300.00000 mm Height: 300.00000 mm
Min X: -300.00000 mm Min Y: 0.00000 mm
Min Z: 0.00000 mm Max Z: 10.00013 mm
Material Thickness = 10.0000 mm
Z Zero = Bottom of material
Machining Time: 02:07:26
OptiFeed Time: 02:07:26
zund - End Mill 6 mm Roughing
Tool: [1] 6.000 mm dia. slot drill
Feed Rate: 200.000 mm/sec
OptiFeed Min: 200.000 mm/sec
OptiFeed Max: 200.000 mm/sec
Plunge Rate: 50.000 mm/sec
Safe Z: 20.000 mm
Spindle Speed: 40000 r.p.m
Stepover: 2.400 mm
Tolerance: 0.025 mm
Allowance: 0.000 mm
Home Position: X:0.000 Y:0.000 Z:20.000
Comments: zund
Feed Rate Length: 124755.0 mm
Plunge Rate Length: 935 mm
Rapid Rate Length: 9789 mm
Machining Time: 00:46:05
OptiFeed Time: 00:46:05
zund - Ball Nose 3 mm Finishing
Tool: [1] 3.000 mm dia. ball nose
Safe Z: 20.000 mm
Stepover: 0.300 mm
Tolerance: 0.010 mm
Allowance: 0.000 mm
Comments: zund
Feed Rate Length: 243616.3 mm
Plunge Rate Length: 12 mm
Rapid Rate Length: 392 mm
Machining Time: 01:21:21
OptiFeed Time: 01:21:21
Thanks in advance.:scratchchin:
