1994 Abene I bought : Can the horizontal ram be moved manually
Results 1 to 6 of 6
    Jan 2006
    Brookfield, Wisconsin
    4,017
    245
    362
    Default 1994 Abene I bought : Can the horizontal ram be moved manually
    Anyone here familiar with this model? VHF340 II, made in 1994. It looks very similar to the current Abene VHF 350 . I had mistakenly thought it was just a newer iteration of the VF3, but this machine is larger and heavier. I'd say it is in the Deckel FP4M size.
    Anyways.., to move it, ideally I need to move the horizontal ram forward to center the weight for transport. But the hand-wheel (Blue arrow) at the back of the ram will not budge, so obviously the axis is locked. I can't find any manual locks for this axis. Does the ram only move in power feed mode?
    I was thinking of bolting 4x4 Douglas Fir beams across the front 2 holes (red box) in the casting, to increase machine's footprint and make it less prone to tip over. But decided I will bolt machine to a heavy duty pallet I have and bolt Doug Fir beams to pallet.
  2. Likes pianoman8t8 liked this post
  3. #2
    Oct 2005
    Pittsburgh, PA
    1,795
    158
    I would think most here would be more familiar with the older single angles ram revision. The VHF 340 that I saw at auction years ago had the locking bolts on the other side. If I remember correctly there were two each for the two different rams. show us a photo of the other side. That machine was not a VHF 340 II however. There would be no need for the hand wheel if you could only move it under power. It might have an electro / mechanical brake also. Do you have the manual and is it still under power?
    I don't like pallets for transport unless custom made for the job and weight . They usually just increase center of gravity height.
    Andy
    Oct 2005
    Pittsburgh, PA
    1,795
    158
    In the link is a photo of the bolts I remembered on the two rams. So yours didn't have these?
    Abene VHF340 U/BS Turret Mill
    Andy
    Jan 2006
    4,017
    245
    362
    Quote Originally Posted by Andy St View Post
    Andy
    From the picture I have, I see the 2 bolts that lock the diagonal movement. Pics I took of the machine won't open and I can't recall if I saw the 2 bolt son top. But the machine in your picture looks just like mine, so it must have the 2 top bolts.
    Yeah I don't like pallets either, especially since the one I have is rather high because it is a pretty heavy duty pallet.
    Could I just attack some 2x4 to 1" plywood to give it some clearance for forks to get under, and bolt machine to plywood? If Machine wants to tilt , will it rip the bolts our of 1" plywood?
    Sep 2008
    Canada
    1,045
    425
    402
    No suggestions for OP, but nice looking mill!
    L7
    Nov 2012
    Maine, USA
    426
    1891
    76
    Even has a quill... drool!
