AlfaGTA
- Dec 13, 2002
- Benicia California USA
Its a bit slow here and thought some might enjoy seeing a project i just finished, involving lots of FP4NC setups involving the "Toolmakers Table (2038).
To begin, i will fill in some blanks. Lampredi was an engineer/designer working for Ferrari in the 50's. He designed a family of engines intended to be used in competition...Sports,F2,and Grand Prix .
The factory built 4, 6 and 12 cylinder engines to Lampredi's design,all with the signature feature of having the cylinder liners screwed directly into the cylinder head/block.
This job required marrying a set of cylinder blocks with oversize liners (OD) to an original crankcase (std housing bore). Now the initial issue, other than the bores which receive the liners in the case were too small,
is that the liners and blocks were re-manfactured after marker parts. These blocks had never been assembled to the original crankcase , and there was no way of telling how well any of it would fit together.
The liners/blocks were made with a total center to center of 540mm for the 6 cylinders on each bank. A distance just within range of my FP4NC at 550...Ok, good!
The position of the liner/receiving bores is relatively critical....clearance between the liner spigots and the bores they nest into runs about .004" on the diameter.
The liners being screwed into the block are quite rigid and any accumulated errors of position would make assembly impossible.
I decided that the best chance for a good job would be to make an accurate "map" of the blocks with their liners and transfer those locations to the crankcase when the over boring was done.
To do this i needed some transferable reference points..The blocks are located on the crankcase using dowels, one at each end and aligned with the center line of the cylinders.
The block is fitted with male ring dowels while the case has receiving bores.
I decided that the natural choice for a constant reference between block and case was ,of course, the dowels. Trouble being that the center to center distance on the dowels was 657mm.
Too far apart to use directly, i needed a way to compress the dowel positions in order to create a new set of datum's that could transfer between block and case....
Below is my solution......Piece of 1.250" MIC6 plate i had in the shop....drawn up and machined as a matched pair.
They are bored and a dowel inserted so that it projects from one side leaving a hole on the opposite side....
The fixtures are also made with a true and straight edge on the top.
There is a reference bore (.500) that is bored at the exact same position relative to the top edge and dowel hole on each of the fixtures...This bore will become my repeatable
reference. In effect i moved the position of the dowels closer together through teh use of the fixtures.
Once i had a way to reach a good reference that i could transfer between the block and case , i needed to setup the blocks on the machine and map the true cylinder positions for both banks (V12)
Here is a holding fixture i made some time back to allow surfacing Ferrari heads ...turns out that the two families of engines (Colombo and Lampredi) both use the same spacing for the
studs that carry the cam carriers on the head...
More to follow....
Cheers Ross
More to follow....
Cheers Ross
