45/5 buttress thread insert availability
Likes Likes:  0
Results 1 to 9 of 9
    Mar 2006
    Winnipeg,Manitoba
    124
    28
    Default 45/5 buttress thread insert availability
    I've been trying to order some W20 arbor blanks from Schaublin. I've got the cash burning a hole in my pocket, but it seems no one who represents Schaublin wants to take my cash.I haven't exhausted this route by any means, but the indifference/lack of response is getting old. At this point, I'm ready to order a stick of stress-proof and make my own. Lacking a tool grinder, and not really wanting to hand work a piece of HSS, I thought I'd check if anyone has found a resource for inserts. Anyone found anything useful,and available? Any alternatives that my idiot self hasn't considered?
    Sep 2002
    Salinas, CA USA
    4,070
    243
    211
    Did you do a search? The topic has come up before...
    Mar 2006
    Winnipeg,Manitoba
    124
    28
    I did. Went through six-odd pages. I'll be the first to admit that my google-foo is weak.
    Jul 2010
    corvallis,or
    877
    90
    369
    GERMANY
    2,884
    1834
    1041
    Hi Millwrong,
    Making it yourself is probably the best alternative because then you can control materials and size to suit your needs. But if you can get by with short blanks, here is one alternative, where they are in stock and will ship in a day.
    W20 shank with S19,7 x 1.666 and 26 mm soft end - RCW20ZG | tool chuck | RCM-PRODUCTION | RC Machines Luxembourg EN
    I have purchased both W20 and W25 parts from RC-Machines. Most were OK although I had to return one part (threaded W25 sleeve for making drawbar) because the thread form was wrong. Second time around they provided a part which fit.
    Oct 2007
    FRANCE
    618
    97
    117
    I have a couple of the W20 arbors from RC Machine and I wouldn't recommend them, they are far from Schaublin quality.
    making them shouldn't be to bad, just grind the bit by hand, it isn't crazy critical given how these threads fit together. (loose)
    the tricky part can by setting the lathe to cut the 1.66mm pitch thread, I had to change some gears on my 135 (from the standard metric setup)
    Luke
    Dec 2002
    Benicia California USA
    8,222
    1895
    2566
    Quote Originally Posted by mTeryk View Post
    Rumor is true, sort of....
    Years back i was able to purchase inserts for both ID and OD 45/5 buttress threads.
    Maker was :Tool-Flo.
    Searching their current web offerings appears that they no longer make or supply these inserts....
    Cheers Ross
    Mar 2006
    Winnipeg,Manitoba
    124
    28
    Thanks all for the help! mTeryk, it scorches me that I missed that post! Oh well, it's Friday; so I will buy you all virtual drinks,and whatnot in appreciation!
    Sep 2008
    Canada
    1,045
    425
    402
    If you’re wanting adaptors for BT 40 or CAT 40, FPS (and others) in Germany sells em relatively cheaply.
