Aciera F3 auxillary table for setting dividing head at a angle
Results 1 to 9 of 9
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    Default Aciera F3 auxillary table for setting dividing head at a angle
    FI have bought a nice Aciera F3 NT 30 with a lott of tooling for resale
    Normal table Swivelling tilting table Slotting head Hor arbor High speed head Dividing head
    But also the table for setting the dividing head at a angle
    What I wonder is how you bolt that thing to the table
    2 T-slots above one and another ?????
    I cannot find any documentation for it
    There are no holes in the tables to get a bolt through
    Also in the middle of that table on the underside is a 10mm pin Probably to rotate on something
    It fits in the t-slot but can still move sideways
    Peter
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    Some more pictures of the accessories and machine
    Still need a good cleaning but most of it is never used
    Enjoy
  3. Likes ballen, BugRobotics liked this post
    GERMANY
    2,830
    1792
    1009
    Nice machine, looks like it's had very little use.
    Dec 2002
    Benicia California USA
    8,175
    1861
    2507
    Quote Originally Posted by Peter from Holland View Post
    Peter
    WAG...perhaps there is some sort of complex wedge style "T" bolt , that fits into both the lower (table) and the inverted upper "T" slots (adapter)...between the table and the adapter.
    Bolts are made so that they pull down using a screw accessed through the side slot on the adapter "T" slot.
    You insert your Allen wrench into the slot from the side and tighten it to pull the adapter down.
    The pin is the swivel point, makes rotating to achieve an angle easier....locates in the center table slot....
    Cheers Ross
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    I was thinking along the same line but why cant I find it anywhere in the documentation or at a machine
    I did have several of these tables already Never with the bolt
    So thats why I asked here
    Sure someone knows
    Peter
    Feb 2001
    Redwood City, CA USA
    5,001
    186
    923
    This topic came up within the past year on the Aciera yahoo group, which is now gone as far as I can tell. The group moved to a Swiss machines forum on groups.io, but the old posts were lost. You might try asking on there. I did not pay a lot of attention at the time, but I think there was a pivot hole in the mill table. The swivel piece you have may not belong to the mill you have.
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    Quote Originally Posted by ballen View Post
    The machine itself has seen some use
    The parts look like they have never been used though
    Also all NT 30
    Also the high speed head and even the dividing head
    Never saw a dividing head with NT30 taper for Aciera F3
    Peter
  9. #8
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    Well It turns out Schaublin picked the easy way out
    They just lett you drill 3 holes in the table
    One for the pivoting pin and 2 for T-bolts
    Peter
  10. #9
    Dec 2002
    8,175
    1861
    2507
    Peter
    Yikes,does not seem very "Swiss",
    Cheers Ross
