Thornewmexico
- Aug 11, 2011
- SW, USA
I had the fortune of recently acquiring an Aciera F3 Helical / Spiral Milling Attachment. I believe Helical Milling Attachment is the preferred term for this attachment, but believe it is more commonly called a Spiral Milling Attachment. Maybe spiral is the proper term used in either French or German, and it has migrated to English.
As I understand it, this item was from an estate sale. The former owner did not exactly keep all the surfaces meticulously clean, or even the machined surfaces mostly clean. It was so dirty that initially nothing fit together properly, and I wondered if the device was actually for my machine. In addition, there were a number of modifications to the original equipment which are incompatible with my F3, but those can be 'easily' reversed. After days of cleaning, this spiral milling attachment is clearly for an Aciera F3 such as I have, so yeah! Now I have to figure out how to use it as there were no instructions which came with it. Depending on how you count, there are three or four types of gears (19 total gears), with two gear tooth pitches, three banjos, two different mounting rails for the banjos, seven total possible gear / centers mounting points, one optional key, (three non optional keys), and two bushings which would permit placing a given gear in several different spots. Simple and compound gearing is permitted. It is similar in some ways to a lathe with a quick change gear box and three levers to choose from permitting many threading combinations. The big difference is that I have to place everything manually. In addition, the only obvious way to mount the Helical Milling Attachment requires drilling of the table. I am okay with drilling on the table (if I must), but don't want to make a mistake based on lack of knowledge.
From what I have seen, there are two very different types of Helical Milling Attachments for the Aciera F3. One attaches to the left side of the table, and one attaches to the right side of the table. The Aciera Catalogs I have seen from the seventies and eighties show only a left hand attachment. Aciera made the F3 from the 50's to the late 80's, after which it ceased operations if I understand things correctly. I have a right hand attachment which I think is older based on the amount of dirt, the styling, and the absence of this item in the catalogs I have seen. You can see the right side attachment in operation here: Le Fraisage - Partie 2 - Les accessoires et diverses fraises - YouTube The applicable time is from 1:50 to 2:17.
My question is: 1) does anyone have a set of instructions listing set up directions, or 2) gear settings for the many different helical combinations possible? Even if you don't have the exact instructions applicable to my model, it is possible that instructions from the later model would give a clue to the method of use for my model. It is conceivable that Deckel or someone else who made this style of attachment might have applicable instructions also for the same reason.
I will shortly be posting pictures of my treasure.
