Aciera square push buttons?
Results 1 to 10 of 10
    Feb 2001
    Redwood City, CA USA
    5,366
    254
    1214
    Default Aciera square push buttons?
    One of the push buttons on my Aciera F5 caved in yesterday. Anybody have recommendations for a replacement? I see lots of round switches, but am coming up empty on industrial square switches.
    May 2018
    CANADA
    Quebec
    242
    243
    77
    When I go looking for a replacement switch for anything, I generally start at Digikey, as they have a wonderful parametric search. This most often links to datasheet or a manufacturer catalog, where you can see the dimensions and specs for the mounting, illumination, contacts etc. Even if you don't buy the component from Digikey, you'll know specifically what you're looking for after you've narrowed down through their search.
    To find a good replacement, you'd want to know the action of the switch (momentary?), the voltage switched, the voltage of the illumination, dimensions of the actuator and the mounting arrangement and dimensions.
    Often you'll find a manufacturer name or mark on the existing switch, and sometimes you can buy replacement parts for even old industrial components.
    Dec 2012
    MN
    127
    38
    rklopp:
    I think you need to remove the switch from the panel and measure the mounting hole dimensions. This will narrow the field considerably. Brands such as EAO, Baco, and Rafi have similar switches and are European companies - EAO is Swiss.
    Regards,
    DB
    Dec 2002
    Benicia California USA
    8,877
    2344
    3280
    Its just cosmetic,yes? If it does not affect the function maybe mill out a window with a step to clean up the broken edges and glue in an appropriate piece of plastic.
    Cheers Ross
    Feb 2001
    5,366
    254
    1214
    I'll probably substitute a modern 30-mm pushbutton. The existing hole is 35-mm-diam, which is an oddball size nowadays, so I'll turn up an adapter ring. The hole is round and not square like the exterior, but there are two small screw holes on the diagonals outside the hole. Unlike 35-mm switches, which seem to unobtanium, the choice of 30-mm devices is almost too far in the other direction, with too many options - NO/NC, number of contacts, color, illumination, illumination voltage, contact rating, flush/protruding, IP sealing, ...
    Oct 2006
    Petaluma CA 94952
    675
    5
    125
    Ive got this new Schluter 19x19mm button if you'd like it. No green button, just blue but free! It is illuminated
    Feb 2001
    5,366
    254
    1214
    Quote Originally Posted by markp View Post
    Mark
    Thanks, but I'll pass for green that costs green $$$.
    Cheers
    RKlopp
    Oct 2015
    AUSTRALIA
    146
    46
    If it helps all the round buttons on my f5 are made by Schneider.
    Sent from my SM-G973F using Tapatalk
    Sep 2007
    Maryland near DC
    416
    90
    88
    Just buy a switch you like and print up a nice intermediate bezel. If you don’t have one it will give you an excuse to get a nice SLA resin printer.
    Feb 2001
    5,366
    254
    1214
    All fixed. It’s a 30-mm WEG LED pushbutton operator from FactoryMation.
  11. Likes rimcanyon liked this post
