AlfaGTA
- Dec 13, 2002
- Benicia California USA
I have a Berco AB 320 at the shop. Dedicated connecting rod machine made in Italy , so i guess its allowed here.
At any rate this machine is used for boring either the big or small ends of connecting rods.
We do lots of white metal bearing work here owing to the age of the engines we work on.
Here is the machine...fairly simple, having a spindle and movable Z axis carrying a vertical slide that carries the rod.
One of the chores in finishing a connecting rod big end is finishing the width of the bearing faces to get the proper side clearance on the crank journal.
For years i have done this work using an indicator and magnetic base to gauge the actual travel of the slide and thus the material removed from the bearing faces.
This method worked, but was not the most reliable and it was time consuming.
Figured that perhaps there was a better way, and i remembered that i had acquired a single axis DRO on a little Myford grinder that i purchased years back.
When i rebuilt the grinder , i did not reinstall the DRO as it seemed unnecessary (was setup on the grinder Z axis.
At any rate i dug out the readout, blew the dust off and connected it to the wall power.....Cool. it works!
Not a new item, a bit shop worn and worst of all it had a membrane key pad on the box...my least favorite entry setup.
Decided to fit the repurposed box and scale to the Berco to read the position of the long slide.
I wanted to mount the scale on the opposite side of the machine from the controls, too much stuff in the way over there.
Problem was that the base was an unfinished casting where the sides sloped (draft)
Fortunately, i have a milling machine, so with a bit of work, removed the head stock, drive motor and electrics, vertical slide and separated the machine from its cabinet/base.
Next stop: Deckel FP4NC......
Base was shimmed and clamped to align the slide (Z) with the mill both horizontal and cross leveled....
The cross slide of the rod machine was fitted with an accessory mounting casting for gauging wrist pin boring, and that casting was going to be the mounting for scale read head bracket....
In the above shot i am milling the under side of that casting to create a flat surface using an end mill. I did not cut the full width of that casting , but rather left a raised island on the inside to act as a reference surface. Note clamps applied to the rod machine slide to hole it stationary while cutting.
The casting was removed for access, and spot faces were milled into the side of the rod machine base. All three spot faces were done by profiling to make flat faces , all done at the same depth and
further drilled and tapped in their centers w/M4 threads.
The spacing correlated to the mounting points for the scale.
The scale was test fitted using stand off's turned and surface ground to the same dimensions. The alignment was tested using the movement of the slide for vertical and horizontal alignment...
One of the advantages here was since the rod machine was on the mill, i was able to use the Deckel to accurately map the locations of all the critical points needed for fitting the scale and the read head.
Take note her of the scale. Bit different form most The scale is housed in a two part extrusion. the rear portion carries the glass scale. There is an outside portion that encloses the housing and is removable to allow easy cleaning of the scale...a nice setup IMO.
Note the three screws at each mounting point. The center larger Allen mounts the rear housing to the machine. The smaller screws on each side hold the outer cover in place. It is possible with this
setup to remove the outer covering with its seal without removing the scale from the machine....pretty slick. Further , the outer housing is sealed to the elements with an "O" ring.
Armed with required mounting dimensions derived from the scale position, i did a bit of design work and came up with a mount to go from the rod machine casting to the read head of the scale....
Then its a matter of some machine work......
More to follow:
Cheers Ross
More to follow:
Cheers Ross
