Axis hydraulic clamping
Results 1 to 10 of 10
    Dec 2014
    ESTONIA
    59
    34
    10
    Default Axis hydraulic clamping
    Does anybody know the principle, how the axis hydraulic clamping works? I see only the pressure lines entering to ways. Hydraulic pump itself keeps pressure, but looks like somebody has disconnected control of the hydraulic valves. Its milling machine SINN, similar to MAHO.p1233426.jpg
    GERMANY
    2,830
    1792
    1009
    I was once shown a nice system used on Thiel 140 or 150 manual mills.
    A long small-diameter plastic tube is placed into a slot on one side of the way dovetail (or perhaps behind the gib strip). To lock the axis, the tube is pressurised with hydraulic oil. This makes the tube swell a small amount, increasing its diameter slightly. That generates pressure which pushes the gib strip against the sliding way and blocks the motion. As I recall, a hand-screw mechanism is used to generate the pressure. It's very effective!
    I do not know if axis clamping on CNC machines is done in a similar way or differently.
    Dec 2014
    ESTONIA
    59
    34
    10
    Its not CNC, just a lightly used manual machine with servos for feed adjustment.Made in 1980.
    I suspect that pressure element is broken and previous owner disconnected the system.If I push the valve open manually, pump starts running and pressure drops down. All three axis behave similar.
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    Take it apart
    Simple
    Peter
  5. Likes AlfaGTA liked this post
    Dec 2002
    Benicia California USA
    8,175
    1861
    2507
    Bruce:
    To answer your question, the Deckel CNC's control the axis movement or lac of by servo action...no hydraulic clamping. Think this is usual for most CNC's.
    Position is held dynamically using the servos...When in use you can remove the cover from the tachometer commutator (connected directly to the end of the servo armature) and you can see it move ever so slightly...hunting back and fourth maintaining position.
    There is a way to "lock" an axis that uses the electro magnetic brake in each servo motor.....They use permanent magnet plates that are released when the opposing plate/coil is powered....Normally the brakes are released when the machine is powered.
    This allows normal servo movement via power or hand .. Lock an axis and the brake is engaged (power off)
    Shut the machine off and the brakes come on...prevents the "Z" axis from creeping down ..
    Cheers Ross
  7. Likes Colt45 liked this post
  8. #6
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    The older Maho with a P controle and Trapezium spindles use a hydraulic brake
    I took some appart a long time ago
    I do not remember how exactly it was But pretty straight forward
    It seems sometimes people are afraid of taking something apart
    In this case it looks like a few nuts removed and one can take of the holding plate on top revieling the mecanism
    Simple
    More time is involved in writing the initial post as it would have cost in getting the answer
    Peter
  9. #7
    Dec 2002
    8,175
    1861
    2507
    Quote Originally Posted by Peter from Holland View Post
    Peter
    Maho also had hydraulic clamping on the manually operated rotary motion (C) of their "universal tables" fitted to their CNC machines....Seems Maho was fond of applying "the juce"
    Cheers Ross
  10. #8
    Dec 2014
    ESTONIA
    59
    34
    10
    But how the pressure is released ?
    I see only lines coming from pressure side of pump through solenoid valves to gibs.
  11. #9
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    Yeah
    What more do you need The solenoid dumps the oil in the tank Pressure is off the mecanism then No clamping then That mecanism has almost and needs almost no stroke
    Peter
  12. #10
    Dec 2002
    8,175
    1861
    2507
    Perhaps the valve has a bleed off port that is open when the valve is off...when energized the valve closes the bled and directs pressure to the clamp mechanism....
    Gotta do a little detective work here as i don't believe it is likely that anyone posting here has a similar machine...so in effect you are pretty much on your own.
    Cheers Ross
  13. Likes priitm liked this post
