Presume the following:
- got a 10"x20"x1" sheet of mild steel
- need to cut 1/2" radius corners on all four corners, accuracy not critical, this is for aesthetics
- my mill is a Deckel FP1
My ideas:
- vertical head, corner rounding end mill, mount work on side in vice, use x-axis to move into work. Concerns: the 20" side exceeds my headroom and thus would have to remove my table and mount directly to z-axis, also concerned about having minimal contact with the work piece with a lot of it extended up without support
- vertical head, straight end mill, mount flat on rotary table, use rotary to move into work. Concerns: don't want to move that heavy rotary table on/off machine just for this little job
- horizontal, corner rounding end mill, mount work flat on table, use z-axis to move into work.
- horizontal with arbor and overarm, corner rounding cutter, mount work flat on table, use z-axis to move into work.
What approach would you take?
My ideas:
