ballen
- Sep 25, 2011
- Garbsen, Germany
The Y-axis handwheel on my mill looks like this:
I'm replacing it with one that has a handle, in the same style as X and Z. Since there is a Y power-feed, I am using a 140mm diameter "safety handwheel" which free-wheels unless one pulls it to engage.
In this photo, I have just slid the new handwheel over the shaft but NOT installed it. To install it I need to drill a radial hole the the desired location on the shaft.
Now I am getting to my question. When I mount this new handwheel, I have a choice. I can include the spacer piece (red arrow). Or I can remove the spacer and mount the handwheel closer to the graduated dial. Or I can make a spacer piece that is thinner.
My inclination is to do this WITHOUT the spacer and to make the handwheel as close as possible to the body of the mill. But my question is, what does this look like on machines where this handwheel is standard equipment on Y? Could someone make a photo and post it, so I can see if / what offset is provided?
Cheers,
Bruce
Cheers,
Bruce
