Deckel 380mm Rotary Table Oil Servicing
Results 1 to 6 of 6
    Feb 2014
    Toronto Canada
    187
    33
    Default Deckel 380mm Rotary Table Oil Servicing
    Hi everyone. I bought a Deckel rotary table at auction without inspection for $150. The table rotates freely and it seems pretty solid without play in any direction. It is dirty and needs a good cleaning. The rotary table has an oil sight glass and it is empty.
    There are two screw on the top. I removed the screws and tried to add oil but it overflows immediately and no oil is present at the sight glass. It is not accepting any oil.
    Before I start tearing it apart to look for blocked oil passages, is there something I am missing in the servicing?
    Dec 2002
    Benicia California USA
    8,773
    2309
    3192
    The two screws work as follows:
    The outer one feeds oil on top of the worm wheel to get oil to the inner two faces of the table support bearings (flat sliding surfaces)
    Oil applied at that hole will not really fill the lower sump (sight glass)
    The inner screw is drilled into the top of one of the retaining bolts for the quick indexing ring (plunger)
    That bolt is special and drilled through to allow oil entry to the lower sump.
    If someone has had the table apart and not reassembled with the drilled bolt in the proper location, the oil will not be able to get to the sump....
    The bolt hole is approx .160" in dia. so you could test to see if the hole is there and open by testing with a small diameter stiff wire (gas/tig welding rod perhaps)
    Might be able to clear the hole if its plugged....or verify that it is even there.....
    To remove the table top, remove the clamp ring with lever and screw from the center bottom of the table, then disconnect the worm from the worm wheel by loosening the clamp and rotating the
    worm housing (front flange) approx 90* to the right (hand wheel should freewheel) ...then you can lift the table straight up.
    Cheers Ross
  3. Likes rimcanyon, Nice Guy liked this post
    Feb 2014
    Toronto Canada
    187
    33
    There is no hole under the inner screw, it is solid. I suspect you are correct and I will need to dig deeper. Thanks for clear instructions on how get it apart. I'll post what I find.
    Feb 2014
    Toronto Canada
    187
    33
    Quote Originally Posted by AlfaGTA View Post
    Cheers Ross
    Exactly right!! The socket head cap screw with the hole in it was in the wrong location. Taking it apart was exactly as you described and it came apart easily. Good thing I had to take it apart, it was full rust colored gunk inside. I'm going to clean it as best I can and put back together. Thanks again!!
    Fernando
    GERMANY
    3,653
    2431
    1464
    Hi Fernando,
    This might be of help: https://www.practicalmachinist.com/v...ndtisch-303095
    There's a pretty good set of photos starting around post 12 or 13.
    Cheers,
    Bruce
  7. Likes Nice Guy liked this post
  8. #6
    Feb 2014
    Toronto Canada
    187
    33
    Quote Originally Posted by ballen View Post
    Hi Fernando,
    Cheers,
    Bruce
    I have read that thread 10 times, it was very useful. Thanks for taking the time to post up all the photos and info. Using a lift (as you describe in that thread) to get it apart made the disassembly easy. I can't say thank you enough!!
    Fernando
  9. Likes ballen liked this post
