Deckel Aktiv Feed Problem
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    May 2001
    Massachusetts
    1,159
    30
    149
    Default Deckel Aktiv Feed Problem
    I've been trying to sort through getting the DC feed drive hooked up for an Aktiv machine (FP3). I've got the feed drive engaging (turning on)- the feeds will work but the run opposite the direction they are supposed to (when moving mechanical engagement levers). BUT they move in the correct direction when the rapid feed is engaged. There are a couple of relevant diagrams (below)-- any suggestions for what to look for?
    Aug 2002
    France
    1,670
    296
    731
    When the feed motor runs, does it work properly but just in the wrong direction ?
    There are a few setting pots on the electronic boards of the DC drive.
    Been a looooong time since I did investigate in that departement and I wouldn't be able to tell you exactly why, but I wouldn't be surprised if the solution of your problem was here.
    May 2001
    Massachusetts
    1,159
    30
    149
    Tien,
    Yes the drive powers the feed motor in the wrong direction for normal feeds; BUT the correct direction for rapid. Something is obviously switched around in the normal feed wiring chain, but I haven't been able to figure it out yet.
    I've played with the adjustment pots a bit- they do not change directionality just the speed.
    a question about engaging the feeds:
    -Turning on the feed motor requires pressing two buttons
    -After the feed motor is turned on, the feed levers can be engaged
    -At this point the machine will start feeding-- is this correct or should the feeds require both mechanical lever engagement and then pressing the feed button on the console?
    Dec 2002
    Benicia California USA
    8,349
    1947
    2685
    Matt:
    When engaging the feed going in the correct direction, does it start immediately, or does it pause, perhaps nudge in the correct direction before then running in reverse?
    Is this a new problem, or is this machine new to you and has never run correctly since you have owned it?
    Cheers Ross
    Jan 2005
    The Netherlands
    6,032
    292
    1622
    Had a somewhat simular problem on a Ferrari once Turned out the wires of the tacho were reversed
    Peter
    May 2001
    Massachusetts
    1,159
    30
    149
    Quote Originally Posted by AlfaGTA View Post
    Once the feed motor is engaged (started) via the console the feed will start (in reverse) immediately after one of the mechanical feed levers is engaged.
    This machine had the feed drive replaced by the previous owner- not with a swap in replacement but a full on different drive where they redid a bunch of the wiring. The replacement drive did not have rapids or creep functionality and it was underpowered. I found an original drive and have been trying to get the wiring back to stock. It's almost there-- but not quite. So the answer to this is no, it has never run correctly while I've owned it.
    May 2001
    Massachusetts
    1,159
    30
    149
    Quote Originally Posted by Peter from Holland View Post
    Peter
    There is a tach input on the DC drive- I will look at that.
    May 2001
    Massachusetts
    1,159
    30
    149
    Peter
    nope, same problem when I switch the Tach wires--- the same in that feed direction is incorrect. There is a change in that the feed motor is in super rapid mode when the feed motor is engaged (feed motor is spinning very fast).
    Jan 2005
    The Netherlands
    6,032
    292
    1622
    I would try to swap both motor and the tach now
    If I do troubleshooting on this system I connect everything directly to the drive
    Also a 10K potmeter for speedcontrole
    That way the motor rotates one direction half the stroke of the pot and the the reverse direction the other half of the potmeter
    In the middle of the stroke the motor stands still
    The additional potmeters in the system make it turn one direction
    Peter
    May 2001
    Massachusetts
    1,159
    30
    149
    Peter
    I just did that (reversed both Tach and motor connections). This results in correct feed direction but the rapids now will not work at all. When I press the rapid button the feeds stop.
    I do have a 10K pot in the console.
  11. #11
    May 2001
    Massachusetts
    1,159
    30
    149
    I found this in an old post by Don:
    I wonder if Deckel ever produced a service manual that tells folks these little secrets... like how best to adjust the various pots on the A1B and A2B ? I noticed for example I could get the DC to drive backwards (allbeit very weakly) if I adjust one pot in particular wrong. They are at least labeled. The large pots on A2B give no clue what they are actually for.
    That was in this thread:
    1980 Deckel FP3, power feed seems "weak" in Z up
    I have not played with the pots on the A1B (DC Drive). The feeds do seem slow (weak?) compared to what I would expect.
  12. #12
    May 2001
    Massachusetts
    1,159
    30
    149
    I found one problem-- a broken trace on the A2B PCB. Repairing this resulted in the feeds advancing in the correct direction.
    Now, Rapids do not work. The speed pot on the console does not effect the speed of the motor. Does not seem to want to lift the Z axis up.
  13. Likes JHOLLAND1 liked this post
  14. #13
    GERMANY
    3,037
    1973
    1114
    Hi Matt,
    Quote Originally Posted by sneebot View Post
    Are you sure it was broken and not deliberately cut? Many printed circuit boards (PCB) have modifications done at the factory which involve cutting traces. Sometimes this is because there was an error in the PCB, and sometimes it's just part of the configuration process for a particular machine or set of components.
  15. #14
    Jan 2005
    The Netherlands
    6,032
    292
    1622
    To determin if it is the drive or something els I would connect a 10K pot directly to terminals 5-6 and 7 and see what it does
    That way you bypass a lott of potentialy faulty parts
    Like explained before speed should go from max CW to stop to max CCW
    If it works fine then the problem is not in the drive If it does not work correctly I would check al the terminals input to start with
    I found that if the tacho and motor + and - are out of sync it does crasy things like randomly pick a direction and overspeeding
    Peter
  16. #15
    May 2001
    Massachusetts
    1,159
    30
    149
    Quote Originally Posted by ballen View Post
    Hi Matt,
    Definitely deliberate- previous owner made a number of modifications to install their 'new drive'. I found it while tracing through the electrical schematic and the PCB vs schematic connections did not match.
  17. #16
    May 2001
    Massachusetts
    1,159
    30
    149
    Peter
    Peter, thanks for the explanation. I will try this-- it may take me a day or two.
  18. #17
    May 2001
    Massachusetts
    1,159
    30
    149
    Peter
    Peter,
    I tried this today. When I connect a 10K pot directly to terminals 4/5/6 the feed motor will start CW, go to zero and then turn CCW. It is not symmetric- the motor will turn faster CCW and there is more of an adjustment window CCW, whereas CW there is very little adjustment. I've not tried to play with the pots on the drive to see if I can adjust/ balance this.
  19. #18
    Jan 2005
    The Netherlands
    6,032
    292
    1622
    Oke So basicly it works I do not know much about electronics but the function of the pot is to split voltage
    So it generates a input ranging from +10 volt to - 10volts That was told to me at least
    Normally I send it out for repair to the OEM for 250 euro But in your situation I would try to turn the pots near terminal 5
    Do you have a diagram ??
    Peter
  20. #19
    May 2001
    Massachusetts
    1,159
    30
    149
    But the reversing of the drive with the pot directly connected is not the normal behavior of the system so the voltages must be modified (0-10V?) by the A2B PCB?
    I played with the pots on the drive a bit and got it more balanced. Now I need to dig into the A2B PCB (with the three trim pots) I believe this must be where the problem is.
    I do have the schematics.
  21. #20
    Jan 2005
    The Netherlands
    6,032
    292
    1622
    I know A2B is for adjusting the stopping of the motor exactly to the position dictated by the TNC 111 or 113
    That is discribed in the manual
    I do not know if it also contains the pots you need But if you look that up you can at least rule out some pots
    Peter
