Deckel fp2 1981 ram disassemble
Likes Likes:  0
Results 1 to 3 of 3
    Jun 2020
    SOUTH AFRICA
    Default Deckel fp2 1981 ram disassemble
    Good day to all my name is Koos. I want to remove the internal bearings because of some noise in the ram. Do anybody know the process since I do not have a manual and do not want to damage any parts? The long gear is mounted on the bottom of the ram.
    Jan 2005
    The Netherlands
    6,592
    356
    1881
    Noise is probably from the 3 gears that transfer power from the long gear to the angle head
    Not too expensive at Singer About €650 IIRC
    When you are at it make a extra lubrecation point to get better lubrication on those gears
    This item has been discussed here before
    Problem with FP3
    Jun 2020
    SOUTH AFRICA
    Thank you very much Peter.
