Boat Brat
- May 11, 2013
- Germany, New Zealand.
Hi All,
I’m starting this thread as a continuation of my how to ship and FP2 questions threads.
Plan is to give some details and pictures for general interest and to possibly help someone else in the future. Along with a place for me to ask for some help myself!
So a general situation to date. I contacted a dealer in South Africa 7 and a half months ago about a 1981 Deckel FP2 aktiv he had for sale, it was cheap.... with reason. The dealer was upfront with some problems. Very noisy gear train, feed drive trips some times, only one speed on the main motor a Swiss cheese table and allot of backlash on the Y axis. I’m sure I will add to that list as time goes on. The other issue being that it is in South Africa and I’m in New Zealand. Any way, a bit of haggling went on and in the end I purchased her for a little under 3k euro. What I hope turns out to be a good deal. Unfortunately shipping cost about the same again.
So, yesterday she arrived! I did ask for a substantial strong box, at around 350kg I think they followed through!
A quick clean up and poke around, first impression is very good. It has been my experience that things often look better in a picture than real life, this machine is actually the opposite for me.
I have had a bit of a look at the Y backlash ( it was a turn and a half on the hand wheel) and found the thrust washer backing plate bolts all very lose. I did them up till they stopped then undid 1/4 of a turn to not damage the thrust bearing. Backlash is now down to 0.2mm on the hand wheel. Obviously with some careful adjustments I will be able to lower this some more. What would be a normal amount? The thrust bearing was packed with dark smelly grease, I assume that this is not correct? It should be oiled? I don’t know why someone was playing around in here. The lock nuts that hold the screw have also been undone and left. The screw has a few scratches on the top of the threads. This will need further investigation.
Now for something that has me a bit puzzled. The vertical head slides on top of the Y axis, it has a nice chain drive to move it. When I first tried this I could only get about 30cm of movement before it came to a hard stop in both directions. Some fiddling with the middle lock and the head now slides a few more cm back. I have pulled the bolts out of all 3 locks, not much to see except that someone has been in there recently. The front lock is currently past the end of the slide so is not a problem, the back lock is on a smooth/ simple section of dovetail so shouldn’t be causing any problem. The middle lock is a bit unknown, it dose wiggle a little even when the pressure is kept on the chain drive against the stop, so this shouldn’t be the problem. Spindles turn fine so I don’t think it is a gear mesh problem.... Anyone have any thoughts on this? I’m a little bit stumped. I’m missing about 40cm travel back and about 5 cm front.
Sorry for the long post.
Regards,
BB
Regards,
BB
