Deckel FP2, drag in the Y axis slides, low oil in the (upper) speed gearbox
Results 1 to 3 of 3
    GERMANY
    2,608
    1611
    903
    Default Deckel FP2, drag in the Y axis slides, low oil in the (upper) speed gearbox
    I was drilling some holes yesterday with the FP2, and when I moved the Y axis there was a drag that I normally don't feel. I ignored it for a few minutes, while wondering if the Y gib needed adjusting, but then a little light came on in my head. I checked the oil level in the upper (speed) gearbox. It was low (below the sight glass). I topped it up (somewhere around a half liter) and ran the machine at 2000 rpm for a few minutes to splash oil around (since that also lubricates the Y-axis slideways). Problem fixed.
    If the Y axis of your FPx machine is dragging, don't ignore it!
  2. Likes thanvg liked this post
  3. #2
    Oct 2017
    FINLAND
    505
    83
    150
    Interesting I did not know that the splashing of oil also lubricated the Y-axis slide ways, I thought the oil container in the headstock did that solely via the wicks.
    Mar 2015
    GREECE
    493
    132
    114
    Quote Originally Posted by DennisCA View Post
    This is the case indeed, but these containers get oil from the gears in there
