Deckel FP2 how to free frozen horizontal quill? - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 73
  1. #21
    May 2018
    CANADA
    Quebec
    42
    17
    5
    The serial number of my FP2 is 5415, which would put it mid-1967?
  2. #22
    GERMANY
    2,596
    1592
    891
    Quote Originally Posted by sigurasg View Post
    That's right. If I understand correctly, you have a 2202 machine, which has the motor hanging out the back (rather than hidden in the base) and 400mm X travel rather than 500. Also a built-in one-shot oiler on the door side and a feed and speed dials which have no hi/lo shifting levers?
    My machine is number 4242 from 1965, so a late-model 2200 machine with the motor in the base, 500mm X travel, and hi-lo shift levers over the spindle and feed speed dials.
    Please post some photos of your machine to confirm this, all we have seen so far is a shot of the horizontal head in post #6.
    Cheers, Bruce
  3. #23
    May 2018
    CANADA
    Quebec
    42
    17
    5
    Quote Originally Posted by ballen View Post
    That's right. If I understand correctly, you have a 2202 machine, which has the motor hanging out the back (rather than hidden in the base) and 400mm X travel rather than 500. Also a built-in one-shot oiler on the door side and a single combined feed and spindle speed dial rather than two?
    That's right, the X scale goes to 16 inches. I don't see a one-shot oiler though - except if you're talking about the nipple next to the sight glass on the door side.
    Ah, I've escaped moderation hell - I hadn't realized.
    Here are a couple of photos:
  4. #24
    GERMANY
    2,596
    1592
    891
    Thanks for the photos. I guess that the one-shot oilers were added later.
    Your machine is outfitted with the standard vertical head. Most of these machines were delivered with the "long-reach" or "adjustable" vertical head that can be shifted back and forth by about ten inches. The one you have is more rigid and precise but less versatile. It also has a slightly different Z offet than the long reach head, can't remember if it's higher or lower.
    Are you missing the settable stops on the Z-travel? I can see them for Y but not for Z.
    Machine looks very clean, but was repainted. The original color is the one inside the door and on the dividing head.
    Rotary table has been fly-cut on the surface, the original finish was a set of planed parallel ridges/valleys.
    Any idea what the aluminium strip is that's been added to the horizontal headstock above and to the right of the Y handwheel? Is that for holding a DRO scale?
    You'll want to replace the damaged X bellows. Easy to find either new or used on German Ebay, search for "Deckel FP2 X-Balg". Be sure to get the one for the 400mm X travel. Left and right are interchangable. They are a bit more than 100 Euros new:
    X - Balg FP2 2200-278 ( X 400 mm) fur Deckel Frasmaschine | eBay
  5. #25
    May 2018
    CANADA
    Quebec
    42
    17
    5
    I don't suppose you can point me to a photo of what the original one-shot oiler looks like? I like the idea of installing one (eventually).
    No, they're present, it's just that the photo is at an awkward angle. I tried to turn the machine to get a better angle, but looks like I'll need a little more manpower to push it away from the wall .
    I've removed the Z bellows on this photo and the uppermost stop seems to be part of that bracket. You can just see the upper movable one on one of the photos.
    Yes, alas it's been repainted, though I knew that going in. Terrible paint job too.
    I hadn't realized that wasn't factory, but looking at it closer it's clear that it's an addition. This is a second scale, graduated by 0.1", quite well done with an inserted steel ruler on an aluminum adapter. Looks like it's glued on the casting and held by a T-nut on the front. I guess whoever did this couldn't bring himself to drilling the casting .
    Thanks - I have the old bellows and they're good except they've let go on a couple of the clips and so were hanging out at the center. I can probably repair them, hopefully just a little bit of a glue-up. Good to know spares are available, however.
  6. #26
    May 2018
    CANADA
    Quebec
    42
    17
    5
    Started cleaning up this morning, found the "coolant" reservoir is full of nondescript oil. Probably a mix of cutting and way oil, for the most part.
    Guess I'll need to find a suitable container for the sundry oil that going to be purged from various reservoirs in the machine.
    I can't find the oil sight glass on the operator side - it wouldn't be mounted behind that dovetail contraption?
    The Z-axis wiper is totally gonsky and the Y-axis wiper blocks are looking a little sad. Looks like Franz Singer will supply a complete wiper set for but a small ransom.
  7. #27
    May 2018
    CANADA
    Quebec
    42
    17
    5
    Nvm, I found it - on the back of the operator-side Z-axis guide block. I thought it'd be on the casting somewhere, but there's no room there.
    Looks like the oilways are clear, leastwise I could pump the sight glass full and see oil oozing up on the operator side. That's a relief, hopefully mine was never greased up.
  8. #28
    Mar 2015
    GREECE
    483
    130
    113
    Hey there,
    Congrats on the new machine, you'll love it.
    Regarding the heads. Long reach end of spindle sits around 60 mm higher than yhe standard, which is welcome always. However, this means that when you are face milling you have to extend the quill in order not to have the headstock hitting your work.... extra rigidity lost here....
    However, single most important feature of the long reach, imho, is that, most of the times, the vertical does not interfere with the horizontal. You don't even need to rotate the vertical and slide it back to work horizontally, you just remove tooling, cover the spindle, and just use the horizontal. This is, to me, amazingly satisfying (because it's useful of course).
    But, on the other hand, standard head is so much more beautiful than the long reach which makes the machine look just like the monster in 'Allien'
    Bruce, I've only seen two 380 rotabs in real life and could not locate any in mr Singer's site (low bandwidth where I am now). Are yoy sure about them being planned-finished?
    Br,
    Thanos
  9. Likes sigurasg liked this post
  10. #29
    GERMANY
    2,596
    1592
    891
    Here's how I added one to my FP2: FP2 vertical table and support tear-down and reassembly
    Thanos, I thought that I had seen some "new old stock" 380mm Deckel rotary tables, and they were planed on top. But I can't find any photos, and am thinking that my memory is wrong. I see that Uncle Franz does plane the smaller Deckel rotary tables like this one: Rundtisch D 230 mm fur Deckel G1L und GK21 | eBay
  11. #30
    Mar 2015
    GREECE
    483
    130
    113
    Hey Bruce,
    Like I said, not much real life experience, I am sure you've seen more in real life. But a quick statistical analysis ( ) based on images on google does not support the 'planned finish' case.
    In any case, sorry for high jacking this thread as well.... I do enjoy discussing such trivialities I admit....
    (If I ever manage to feel so sure about my mill's tramming, I'll fly cut mine as well, I find the finish you showed on that early thread Bruce to be very attractive).
    Br,
    Thanos
  12. #31
    Dec 2002
    Benicia California USA
    7,965
    1771
    2319
    Think the factory finish on the top surface of the rotary table was a "Blanchard style" ground finish.
    This leaves a finish with semi circular lines form the grinding stone...might be mistaken for a fly cut surface....
    Not seen an original table with a planned surface, but like all things Deckel might have to do with the age of the table...
    I have two in the shop now ,both originally had the ground surface (one has now been scraped overall) also, one does not have the sight glass for the oil level in the base....so there are differences.
    Other thing about the long reach head is its shear weight......My own personal opinion is that it is heavy for the surface area or the "Y" slide.....
    Making the "feel" of the "Y" heavy and less sensitive....Also likely to incur higher wear on that slide.....
    Nice to have the extra reach, but it comes with other costs.
    Cheers Ross
  13. Likes ballen, Lumberjack liked this post
  14. #32
    Aug 2018
    12
    7
    7
    The finish on the rotary table is a Blanchard ground finish (or the German equivalent). I have seen several of the 380mm rotary tables with this finish and assumed it was factory. Here is a rotary table from Franz Singer with that finish:Rundtisch gebrauchten D 380 mm fur Deckel Frasmaschine | eBay
    The rotary table that I have has this finish also.
    Regards,
    Nigel
  15. Likes ballen liked this post
  16. #33
    GERMANY
    2,596
    1592
    891
    It's a good idea to replace these wipers, even though they are pricey. Maybe someone here has a spare set they can sell you for less.
    In addition to these wipers, and the Z bellows, to protect both Y and Z on my machine I use this "bib" almost all of the time. It's often missing.
    Fuhrungsschutz 2200-570 Y- Achse fur Deckel FP2 Frasmaschine | eBay
    I got a used one for a few Euros, but it's easy enough to build. You turn two "buttons" that are a loose fit in the holes bored at the ends of the headstock T-slots (see photo above). Then bend up a piece of heavy steel wire into the correct shape, and sew a leather or heavy cloth "bib" onto it.
  17. #34
    May 2018
    CANADA
    Quebec
    42
    17
    5
    Yeah, I need to make up a shopping list of things I need from Franz Singer. This is my first manual mill and will be with me for decades to come (knock on wood), so I'll do the needful. I want to get'er going and see what's what before I go crazy on buying things.
    ... I use this "bib" almost all of the time. It's often missing.
    Yup, it's missing.
    Another thing that's missing is the protective cover for the dovetails on top of the ram. With the standard head, I can't leave it in place when I use the horizontal spindle, so that'd be nice to have.
  18. #35
    GERMANY
    2,596
    1592
    891
    Here's one on German Ebay for 30 Euros:
    Deckel FP 2 Abdeckung | eBay
    I think the weight is under 2kg so DHL shipping to the USA adds another 20 Euros.
  19. Likes sigurasg liked this post
  20. #36
    May 2018
    CANADA
    Quebec
    42
    17
    5
    Thanks! Are these interchangeable across all versions of the FP2?
  21. #37
    GERMANY
    2,596
    1592
    891
    I don't know if they are interchangeable across ALL versions of the FP2. But I am sure that it will fit YOUR version of the FP2.
  22. Likes sigurasg liked this post
  23. #38
    Dec 2002
    7,965
    1771
    2319
    That cover if for the "round Head" style machine...the version where going to horizontal requires removal of the vertical head....
    The later "square head" machines do not require removal of the vertical head, but rather simply sliding it to the rear.....
    The cover for those machines when running horizontal is different.
    Flatter to allow nesting below the vertical head.
    Cheers Ross
  24. Likes sigurasg, ballen liked this post
  25. #39
    May 2018
    CANADA
    Quebec
    42
    17
    5
    So, looks like I'll have to take the table off to get the mill into my workshop. It's either that, or I'll have to take the wall out between the garage and the workshop, and even then there's a column I'm not sure I'd be able to snake around. With the table off, it's a straight shot to run it down the hallway on a pallet truck.
    Getting the table off and looking at the ways is probably also not the worst of ideas. The sight glass on the operator side of the mill looked pretty cloudy, so I'm worried there might have been a shot of grease in there at some point.
    Is it a big job to get the table off? Do y'all happen to know about how heavy the table is?
    Also, is there a way to rename this thread, or should I be starting a new one? This is no longer about a just the seized quill...
  26. #40
    Mar 2015
    GREECE
    483
    130
    113
    10 min job: go to the door side of the carriage, renove leadscrew end cup, undo nut. Now undo the cover (a couple of allen screws) and tap it out. You can now just rotate the leadscrew until the table comes off, operator side.
    SUPPORT it well.
    I guess this is the fast way but you risk bending stuff if you don't have excellent support.
    Optimally, remove leadscrew alltogether (couple or ring nuts at the inside or the operator side carriage cover) to be safe.
    Undoing and removing gibs will help, mostly in reassembly.
    Might be forgetting something, others will chime in if I got something wrong!
    Br,
    Thanos
  27. Likes sigurasg liked this post
