deckel fp2 quick tool question
volvo 140140
Jan 8, 2018
Hi, I wonder if anyone would like to answer a question. I have a deckel fp 2 and use the original drawbar.I have bought drive ring 1mm of singer and then pullstud M16-S20x2 and used with sk 40 DIN 69871 tool this works perfectly. but I wonder if I can use this drive ring and pullstud M16-S20x2 with these tools also BT40 (JIS B 6339. best regards
I haven't looked at the specs so don't know if the pull studs will work. Easy enough to change them for the right ones.
The drive plate is incompatible. I made one for CAT40. Drive dogs are different dimensions and the plate had to be thinner. Should be similar with BT40.
Teryk
