Deckel fp2 vertical spindle ( Lock nut) - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21
    Oct 2017
    FINLAND
    734
    121
    226
    I believe volvo 140140 is talking about putting the horizontal spindle back together.
  2. #22
    Jan 2018
    SWEDEN
    59
    Yes Dennis is right I talk about the horizontal spindle / quill. have trouble getting it into casting do not know what to call it.By lock ring I mean the one that is used to lock the quill when you ar milling. Best regards volvo 140140
    Skickat från min SM-N960F via Tapatalk
  3. #23
    Dec 2002
    Benicia California USA
    8,295
    1928
    2622
    Ops...totally missed that.
    Spindle "Quill" (the outside portion that can be moved and that fits into the machine casting) needs to fit the housing closely......
    Any differential heating such as holding it in your hands while the machine is in a cold shop can cause installation issues.
    Early FP2's have issues with the locking rings on the horizontal quills. Dirt and old coolant and accumulate around and behind the ring making it tight and unable to unclamp
    correctly.
    Removal and cleaning of the ring and cavity it lives in seem to be the remedy
    Have a look here:
    Removing an FP2's Sticky Horizontal Quill
    Everything must be clean,
    Cheers Ross
  4. #24
    Jan 2018
    SWEDEN
    59
    Hi thanks. I removed the lock it is little differently than the one in that thread. Maybe they changed it to the newer models
  5. Likes ballen liked this post
  6. #25
    Jan 2018
    SWEDEN
    59
    Hi. I've started assembling my horizontal spindle now, There are two lock rings what i'm thinking about is which one to use to put the axial play. suppose you do it on the inner locking ring? On the outside, you just tighten the trust bearings. Is this right ? How much to tighten the outer ring that is to hold the trust bearings in place ? Thanks best regards volvo 140140
  7. #26
    Mar 2015
    GREECE
    636
    193
    168
    Quote Originally Posted by volvo 140140 View Post
    Bruce shared some precious information that he got from Mr. Singer here:
    1964 FP2 horizontal spindle adjustment
  8. #27
    Oct 2004
    Denmark, Scandinavia, Europe
    755
    28
    70
    Hey,
    the spare parts manual I posted a Dropbox link to, is actually for your vintage of FP2.
    Unfortunately no drawing of the horizontal spindle, but the heads are there.
    Cheers (hej då)
    Erik
  9. #28
    Jan 2018
    SWEDEN
    59
    Hi. yes I see that now. thanks so much. should read through it. Best regards, volvo 140140
