I asked about G64 and didn't get an answer here. It's not documented well in my manual either. It does work outside of G41. I found that the G40 turned G64 off, and I had to put G64 on the next line if I wanted it to continue to be effective. When cutting a series of small arcs or line segments, G64 made it smoother and prevented the stops at the end of each segment even when cutter comp was not active.I can't tell you why G64 does anything outside of a G41/G40 compensated path. I don't think it's documented in the manual.
G's are not modal on a Dialog control ?N26 G0 X-1.643 Y-5.461 Z5
N28 G0 Z1.125
N30 G1 Z-1.625 F80
N32 G1 X-0.276 Y-4.001
N34 G3 X-1.643 Y-3.461 I-1.367 J-1.46
N36 G3 X-3.103 Y-4.095 I0 J-2
N38 G3 X-3.22 Y-4.225 Z-1.681 I3.103 J-2.903
Having said that, I don't see anything in the OPs code that would turn it off. Do you still see G64 on the monitor while it is pausing? If you switch to distance-to-go mode do you see zeros on the screen for all 3 axes at the pause? If you turn the speed override way down to give the control more time to process does it still pause?
Antediluvian ! Gotta hand it to the germs, if they can make it unnecessarily complex, they will ...G0, G1, G2 & G3 are not modal. G81 82, 83 is not, either.
I don't view it as more complex, just different. In the modal, case, things get complex real fast if you forget to turn off modes like G0 or G81. Dialog is 35-year-old CNC, too.Antediluvian ! Gotta hand it to the germs, if they can make it unnecessarily complex, they will ...
Well at least you don't have to load the exe. with paper tape....
And G1 might easily be seen as "modal' in that any move not otherwise defined is understood to be a G1....
Cheers Ross
I like having the paper tape ! That way if something happens the damn control isn't just dead forever ...Well at least you don't have to load the exe. with paper tape ....
Ja, that's what I'm talking about. When those go out, like bubble memory or magneto-optical with a lifetime of 200 years or my core memory that never goes bad, you're screwed.Entire operating system is on E-Proms....
Notice
